Free Mot
Started by Kieran, 10 September 2018, 20:47:17
Kieran
Halfords are offering free MOT with any purchase at store or online. Purchases must be made between 10th September - 14th October. MOT valid till 31st October 2019. Obviously they will try and get further work out of it but worth a try.
redelitev6
"Free" and Halfords, mmm  ::)
dave the builder
hardly a free MOT
they will fail it and charge you stupid amounts to fix what they found.
like £30 per headlight that needs adjustment etc
ATL test with shaker plates ,will highlight even the slightest play in anything
(so expect to pay for new shocks,bushes etc)
your "free MOT" will probably cost you £500+
JM2PW
zirk
A Free Mot with Halfords, think I would rather piss on a spark plug with the engine running at 6000 rpm  ::).
Quote from: zirk on 10 September 2018, 21:20:42
You've tried that too? Good, innit?  :y
b4ndit
Think i might go for it could be a laugh ;D
deviator
Couple of questions...
1. Is the plug in the engine?
2. Is the HT lead /COP attached?
zirk
Quote from: deviator on 11 September 2018, 08:09:22
1. Is the plug in the engine?              A.  Doesn't have to be, but helps to get the Engine up to 6000 rpm.
2. Is the HT lead /COP attached?       A. Yes, this is Mandatory.
dave the builder
so on the windscreen  :-\ to wet plugs 2,4,6  :-\
not easy on a DBW engine to hold the GO pedal and reach the screen  ;D
zirk
Quote from: dave the builder on 11 September 2018, 12:28:36
Just takes practice, I can get to my Neighbors BMW from my Bedroom window.
deviator
Quote from: zirk on 11 September 2018, 12:33:37
Just takes practice, I can get to my Neighbors open top BMW from my Bedroom window.
Better
zirk
Quote from: deviator on 11 September 2018, 12:38:37
Better
Open Sun Roof, gives a better Aroma come Monday Mornings.
dave the builder
SKILLS  :y
tell him to take his BMW to Halfords , apparently they do free MOTs  :D
(and air freshners)
Tony H
Quote from: Kieran on 10 September 2018, 20:47:17
Hmm just ask them that if the car fails can you take it to your local garage for repairs and then return for a re test  ::)
deviator
Quote from: dave the builder on 11 September 2018, 12:28:36not easy on a DBW engine to hold the GO pedal and reach the screen  ;D
When I need to hold revs on a car I use a sealant type squeeze gun and the handle (or a straight bit of pipe/tube) from one of those £20 jacks (which I don't use anymore). You can wedge the gun handle against the seat and then squeeze the handle which pushes the pipe onto the throttle.
