Trip to the dentist.
Started by Field Marshal Dr. Opti, 27 September 2018, 16:10:04
Three teeth are basically past saving and because of this eating is becoming a problem. They need to come out.
I don't want a denture, they are for old people. Another option is a dental bridge but these tend to damage the good teeth either side of the one that is to be pulled, and can cause more problems than it can solve
Anyway, I've decided on three dental implants which should last me until I'm placed six feet under.
Today I've had a CT scan to check bone density ( £240)........I will then need to have  the teeth extracted before the butchery can commence. :)
Should take about five of six months in total.
So .. this is Opti on a day out?
Quote from: aaronjb on 27 September 2018, 16:13:42
No....I'll have a whiter than white Hollywood smile.
I believe that is a picture of either STMO or Albs.
Lizzie Zoom
Best of luck Opti!! :o :o :o
Teeth can be a real problem, and like you have I had to lose some.  Not good.
The dental plates are horrible, so I have tried the ones you mention that clip into the teeth either side.  But that became uncomfortable and in the end I gave up on it!! ::) ::) ::)
You have the right idea in having implants, but the wallet will suffer!  Still, you Lord are such a rich bugger you can afford it ;D ;D ;D ;D ;)
All the best with it and hope the treatment does not hurt too much :-* :-* :-* :y
Quote from: Lizzie Zoom on 27 September 2018, 16:27:49
A dental bridge is far more sophisticated and expensive than an old-fashioned denture that goes in a glass at night, Lizzie. Around £1500-£2500 for a three unit bridge. They are available on Band 3 of the NHS for £256........but in reality the NHS will not offer this course of treatment as it is too costly. People are either forced to pay privately or take the denture option. :-\
Quote from: Doctor Gollum on 27 September 2018, 16:39:07
https://youtu.be/bOtMizMQ6oM
Lucky I'm not squeamish. ;D
As a kid the dentist used gas which was not nice. :-\
Parents not allowed in the room even though I was only seven or eight years old. I can still recall the smell of the rubber mask and the hissing gas as the dentist pinned you down until you stopped struggling. :)
Character building, apparently. :)
amba
Get the "Top Two Pulled and the Bottom One Filled ".............nice  ;D
Lizzie Zoom
Quote from: Field Marshal Dr. Opti on 27 September 2018, 16:37:45
Yes, I had the dental bridge small type and it cost about £415.  It was flexible and fitted well first of all.  Stopped using for a couple of weeks and I just went off of it.  Never actually had one of the old fashioned plates myself, as only old people had those I thought( ;D ;D) but I know I would gag on one if I did, like I used to on my teeth brace when I was 7. :D ;)
Varche
How about a bit of health tourism.?
A few years back a family member came to Spain for similar dental work. Even with flights it was cheaper. Prices are somewherebetween nhs and rip off uk private.
Quote from: Varche on 27 September 2018, 17:32:55
I've considered this but I would need to make three or four trips.........so not really cost effective.
Quote from: Lizzie Zoom on 27 September 2018, 17:11:52
Dental bridge is permanent Lizzie and can't be removed unless broken. :-* :-* :-* :-* :-*
Lizzie Zoom
Quote from: Field Marshal Dr. Opti on 27 September 2018, 17:34:48
Hire a villa with a pool Opti!  Do what some expats do! :D :D :D :-* ;)
Good excuse for a long break from Brexit talk! ;D ;D
Lizzie Zoom
Quote from: Field Marshal Dr. Opti on 27 September 2018, 17:36:26
Ah, right!  I obviously didn't know that.  So they are different from implants? ??? :)
Quote from: Lizzie Zoom on 27 September 2018, 17:37:52
The crown part is the same but with a dental bridge it is cemented over an existing tooth that has been filed down. With a dental implant the tooth is removed and replaced with a screw that fits into the jaw.The new crown is then screwed into the metal implant.
