Conservatory roof.
Started by Shackeng, 16 October 2018, 19:38:36
Shackeng
Does anyone have knowledge or experience of the various systems offered for insulating conservatory rooves?
Quote from: Shackeng on 16 October 2018, 19:38:36
Roofs.
Shackeng
Rooves as a plural for of roof is dated, but not incorrect. The Oxford English Dictionary lists "rooves" as an alternate to roofs, one of several outdated spellings used in the UK, and in New England as late as the 19th century. :P
Sorry, Chris, I forgot your were in your nineties.  ;D
I have a conservatory, I insulated the walls etc l, with kingspan stuff, added proper radiator.
Problem is conservatory's are shite, foundations tend to be crap and floor is not insulated either. It's like trying to heat a kitchen cullender.
I'm now favouring bulldozing it and building a proper extension.
Shackeng
Quote from: STEMO on 16 October 2018, 20:52:31
0uchh :(
Shackeng
Quote from: tunnie on 16 October 2018, 21:11:41
Mine has proper foundations, 100mm insulated floor, underfloor heating, and radiators, (I was site foreman), but of course still loses heat through the double glazing. There are several companies offering either internal, effectively, ceilings, or external insulated roof panels. :y
Quote from: Shackeng on 16 October 2018, 22:23:35
Sounds better than mine then, I did look at replacement roofs either whole and tiled type or panels. Mine is double glazed roof.
Seriously expensive for what they are, If foundations are strong enough it would probably be similar price to build normal extension, they are that pricey!
Conservatories should be banned in my view, horrible things. Hate mine with a passion.
Anna RyderRichardson of failed zoo fame is currently flogging conservatory roof insulation panels on the tellybox :y
Quote from: Doctor Gollum on 17 October 2018, 01:32:58
I bet she's great in the sack!  :-*  Dirty Ryder!  :y  ;D
Quote from: Shackeng on 16 October 2018, 19:52:11
Does the same apply to 'hoofs 'and 'hooves'?
I see a lot of the word your incorrectly used in place of you are or you're on this forum.  :)
Quote from: STEMO on 16 October 2018, 19:50:23
Roofs.
Mr Shackeng was a pilot for forty years. He won't take kindly to being lectured on the finer points of spelling and punctuation by an errant scouser. :)
Viral_Jim
Some friends of mine looked into this for their conservatory and came to the conclusion that by the time you'd paid out on the ceiling you may as well have demolished and built an extension in its place.
I'd seriously look at that instead, particularly if the foundations are good enough to support it already.
Quote from: Field Marshal Dr. Opti on 17 October 2018, 11:58:23
Roofs.
Please do NOT insult the honorable gentleman ... he never was past of the "drivers, airframe, for the use of" branch of Her Majesty's Royal Air Force ..... please note his screenname .. shackENG ....
However as a Master Engineer of some seniority he would have often taught junior pilots the intricacies of correct Service Writing ...
:D :D :D
