Author Topic: Dashboard Problem  (Read 4441 times)
FX.997
  • Syria
    • Opel Omega 2000 3.0v6
Dashboard Problem
« on: 23 October 2018, 16:34:10 »
Hello, I own Opel Omega 2002 3.0V6
I got dashboard lamps and I replaced them using the guides in this sites
Everything worked perfectly but the sports button light won't turn on on the dash unless i push the dashboard in (by force)
Then it stopped working at all, what might have caused the problem?
Please help me and thanks.. I'm new here.
Re: Dashboard Problem
« Reply #1 on: 23 October 2018, 16:37:22 »
Loose bulb, remove, check, refit and report back :y
« Reply #2 on: 23 October 2018, 17:51:27 »
Souds like dash isn't quite correctly seated.  Lift it off the connector and push back on securely.
FX.997
  • Syria
« Reply #3 on: 23 October 2018, 19:05:21 »
Okay wil do thabks alot
« Last Edit: 23 October 2018, 19:07:39 by FX.997 »
FX.997
  • Syria
« Reply #4 on: 23 October 2018, 19:06:21 »
Is there a proper way or a tutorial that i can follow to do that? Thanks in advance
« Reply #5 on: 24 October 2018, 16:58:30 »
Remove the 2 screws that hold it in (sorry, that means removing air vents etc), pop it off the connector, ease it back on the connector, then with flat hand on rev counter firmly press back.  You should feel it seat on correctly.
FX.997
  • Syria
« Reply #6 on: 24 October 2018, 19:54:13 »
I tried that today twice..
Every single bulb works but the sport bulb doesn't i replaced it i tried everything i tried poping the dash back twice in the same position and still same result... any other advice? Thanks tho
