Author Topic: Central locking ECU..replacement.  (Read 10872 times)
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« on: 16 November 2018, 17:57:31 »
I need to find the correct replacement central locking ECU for my 2000 F/L ex plod 3.0 MV6. I was looking through a post from a couple years back in which Dr G pointed out that the plod 3.2's had an Elite loom for the fitment of the CL ECU, does any one know does that apply to the 3.0 as well? :-\
Re: Central locking ECU..replacement.
« Reply #1 on: 16 November 2018, 18:09:40 »
The engine is irrelevant.  Its the car spec.  GLS and below are Central Locking. CD and above are ATWS. FL Estate is different to FL Saloon.
If a saloon FL, I'd suggest getting one from a later car to avoid that annoying having to remove key from ign to open the boot.
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #2 on: 16 November 2018, 19:55:06 »
Thanks for the info Jamie,Omegas 52 has a few but is there any way of identifying the correct item,because they all seem to have different part numbers on them.
« Reply #3 on: 16 November 2018, 20:08:44 »
There will be a yellow sticker with two letters on it. Match the letters and the part number doesn't matter ;)
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #4 on: 16 November 2018, 20:18:27 »
Cheers Al will take look in the morning :y
« Reply #5 on: 17 November 2018, 10:25:22 »
Or go for later one, with the better boot opening ;)
« Reply #6 on: 17 November 2018, 10:25:50 »
OP - Central Locking or ATWS? Saloon or Estate?
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #7 on: 17 November 2018, 10:35:31 »
Ex police saloon so no anti theft, tried an alternative solenoid but still has the same problem....hence the faulty ECU theory. I'm going out to the car and taking a look at the ECU for a part number :y
  • Auckland
    • Mazda MPV
« Reply #8 on: 17 November 2018, 10:55:51 »
What is the problem?
I would be looking to repair broken wires in the door looms near the door Hinges before I started worrying about swapping ECUs
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #9 on: 17 November 2018, 10:59:46 »
that would be my advice too. I sold my car before fitting the replacement door loom.
« Reply #10 on: 17 November 2018, 11:23:29 »
Rewelding the check strap has the potential to cause issues... Ecu lives behind it ;)
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #11 on: 17 November 2018, 12:32:11 »
The ECU is working...but when unlocking the car with the fob it unlocks and then re locks instantly,but only on dry days, damp days works perfectly.Door strap was done a long time ago by Serek and as we know he's done quite a few in his time,and all wires etc are in good condition.The only large letters on the ECU are CG  but not yellow :-\
  • Chatham, Kent
« Reply #12 on: 17 November 2018, 12:38:49 »
That's exactly what mine did, but was worse with the door open. I would still be checking the wiring.
« Reply #13 on: 17 November 2018, 12:39:48 »
New door motor :y
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #14 on: 17 November 2018, 12:53:21 »
Had a new one ready but wasn't needed,a little on the slow side but lubed up and works O.K. All done at Serek's yesterday,so I'm sort of working at his request to locate another C/L ECU. ::)
