An Electrical Question
Started by Figureman52, 28 November 2018, 09:37:47
Figureman52
Hope someone can help.
I have a couple of floodlights wired  together and operated through an ordinary light switch off the lighting circuit, which is not RCD protected. If I connected another feed to them via a separate pir detector coming off the ring main, which is RCD protected, would it work, or is it likely to keep tripping out?
Thanks.
dave the builder
That is a BIG NO NO !  :o
and if you have to ask ,you should seek out professional help.
and your current light switch controlling the lights should be a double pole switch anyway ,preferably a switched fused spur
Lizzie Zoom
Quote from: dave the builder on 28 November 2018, 10:58:30
Indeed!!
Last year I had to urgently disconnect a security light on the side of my daughters house that was running off the ceiling rose in her bedroom without any isolation switches, fused spurs, and running on 2.5 cable, which really reflected the lack of knowledge of legal electrical installations and regulations by whatever idiot installed it all!
As Dave says, if you lack the knowledge to carryout such work, then do not do it and only allow suitably qualified electricians to do so.  That could avoid you being prosecuted if things go very wrong. ;)
dave the builder
Yes , there are some bad DIYers out there that give us proper cowboy builders a bad name  ;D
Electricity is very expensive and you don't want it leaking out all over people  :P
Figureman52
Thanks for the advice. :y It felt wrong to me anyway, which is why I asked.
Not if its off a lighting circuit it doesn't, single pole is absolutely fine.
The real issue is the wattage of the outside lights, if they are stonking halogen jobs then they will exceed the rating of the lighting circuit.
Agreed you need a fused spur (plus appropriate rated fuse) with isolator if they are fed from a ring main to provide the correct upstream protection.  :y
Quote from: Lizzie Zoom on 28 November 2018, 11:50:37
Indeed!!
Virtually nothing wrong at all with that Lizzie, 2.5mm is fine assuming it fits the terminals ok, feeding an outside light of the lighting circuit is also OK as long as the circuit is not overloaded, isolation in this application only has to be available to the live connection.
I have two outside security lights fed from a single pole switch in the kitchen, on the lighting circuit. The are 10W leds.
Viral_Jim
Quote from: STEMO on 28 November 2018, 13:03:38
From the sounds of it, it's a miracle you haven't burned down half the street. Lizzie will be along imminently to chastise you vigorously!
dave the builder
Quote from: Fuse 19 on 28 November 2018, 12:54:07
It's an outside light ,so special location, requires double pole isolation from the lighting circuit which someone decided to connect it to,
fused spur is a double pole switch
if the outside light is powered by a plug (with correct sized fuse),which can be removed from a socket *with RCD protection (thus giving double pole isolation) it is effectively a portable appliance, not notifiable.
in this case, the lighting circuit is RCD protected ,(from what the OP said)
However, not all installations are up to date ,dual RCD consumer units or better.
some are ye olde wylex re-wirable  antiques with no RCD or even decent overcurrent protection  ::)
so when water gets into your cheap Chinese LED security lights , how do you isolate them ? assuming your still alive ?
are your lighting circuits RCD protected ?
you'll need a torch to see to reset the RCD because  it will have taken out your lights too (if night time ,but such problems rarely happen in daylight or at convenient times)
Migv6 le Frog Fan
My outside security light is wired to a 13 amp plug and plugged into a socket in the bedroom.  :-\
dave the builder
Quote from: Migv6 on 28 November 2018, 13:32:32
wow , do you have a massive back garden that requires 3 kw of lighting  :-\
or have you put the correct rated fuse in the plug  ;D
also, have you checked your upstairs sockets are rcd protected ?
some older installations had downstairs RCD protected sockets only (in case you plug a mower in and decide to mow the lead) some don't even have RCD at all .
STAY SAFE people , this newfangled electrickary is nasty stuff
(check your electric bill if you don't believe me £££  ;D )
Lizzie Zoom
#12
Quote from: Fuse 19 on 28 November 2018, 12:57:25
Indeed!!
I was making the point that whoever used 2.5 cable to a lighting circuit was showing a lack of knowledge, as no electrician would use that rated cable in such a manner.
As for a switch to the live, there was nothing in any form of switch and isolating fused spur. Therefore if the external light had become faulty it would trip the lighting circuit breaker and, without climbing up ladders to find the fault, would have resulted in the lighting being off for some time as anyone investigating the fault would not have known for a bit that the outside light was causing the problem.  There was no visible sign of any connection internally, and no way to isolate the external circuit.  To me that is at least bad and unsafe practice. ;)
Yes, mine are RCD protected. They were neither cheap nor Chinese, I fitted them, not a cowboy builder.  ;D
The lights are sealed units, with a tail, which is wired into a weatherproof junction box.
Varche
How many forum members does it take to answer an electrical question?
23 including one real cowboy builder to give the correct answer, ten other also correct answers, one to call the fire brigade and one smart ass to make a funny comment .
PS STEMO. 10 w LED security lights? They are underpowered. Even pointing in the right direction they will be unable to illuminate your neighbours bedroom fully as they switch on and off each time a fox, cat or Amazon delivery van goes by. Two of these for example but they would need their own fused spur!   https://www.ebay.co.uk/itm/300W-LED-FLOOD-LIGHTS-INDUSTRIAL-HIGH-BAY-STADIUM-SECURITY-FLOODLIGHTS-UK/291414522263?hash=item43d9a8b997:m:mAsdOYnC3QPp3ttlhaUTTBg:rk:3:pf:0
