Author Topic: anybody remembers  (Read 6343 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
anybody remembers
« on: 27 December 2018, 21:15:33 »
 i was having a a conversation with a mate of mine that happens to a small car repair shop. we mention when cars reach about 180k on the clock they are considered to be getting towards the end. both of us said we remembered a lot of old vehicles that had clocked 500,000
 mls . the m.ot. put lots in the knackers yard . i owned a pug pickup that had over 380,000. it did chuck out loads of black smoke though.
Re: anybody remembers
« Reply #1 on: 27 December 2018, 21:28:41 »
Most mass produced cars of the 50's and sixties were knackered at 60,000.
« Reply #2 on: 27 December 2018, 21:31:21 »
My second Omega was just over 280k when I sold it, current transport, an '02 Mercedes A160 is almost at 180k... Modernish cars will do proper mileage as long as you want them to...  8)
Regular servicing is a must ;)
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #3 on: 27 December 2018, 23:49:12 »
^^ this.
Cars these days die due to neglect I reckon (disregarding corrosion on certain marques - mid-00's mercs, newer Mazda's etc). People believe cr@p like "sealed for life" and use it as an excuse to neglect correct maintenance.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #4 on: 28 December 2018, 08:35:26 »
In the late '90s I bought a '84 reg Senator and that going on the paperwork that came with it was nearing 260,000mls when I bought it! People taking the head off earlier cars to do a de-coke was a regular occurrence at one time.
« Reply #5 on: 28 December 2018, 08:46:42 »
The killer for modern cars (mechanical, that is, rather than it being last year's badge) is the extended service intervals.
My old beloved Silver Bullet was over 230k, and the engine was absolutely sound, with the only real mechanical issue being its temperamental gearbox which had had a hard life over the years.
Keith ABS
  • Maldon Essex
« Reply #6 on: 28 December 2018, 09:11:51 »
 I sold my manual 12V Carlton GSI with 380,000 miles on it. Was still going strong on origional engine and the head had never been off. Had to replace a gearbox though
Migv6 le Frog Fan
  • Online Online
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #7 on: 28 December 2018, 09:47:41 »
In the 70,s it was expected that an engine would have the head off for a decoke at around 30,000 miles, if a car had more than 70,000 on the clock you haggled hard on the price because buying it was a gamble, and anything with near 100,000 was scrap value only.
As said, modern cars will go on almost forever if serviced properly and often.
I had the owner of a new BMW listen to the sound (or lack of it) of my Omega engine yesterday, and he couldn't believe it has 182000 on the clock.
« Reply #8 on: 28 December 2018, 11:09:35 »
Yep. Back in the day it was common for cars with only 50,000 miles to be advertised as 'just having had a rebore and a decoke'.
I imagine the manufacturing tolerances are much 'closer' these days, and the oils used are far superior. Castrol GTX was a 20/50 and like treacle when cold.
Car performance for 100,000 plus mile cars seems to be much the same as when new which was not the case if you owned a 70,000 miles Austin 1100.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #9 on: 28 December 2018, 12:04:56 »
the biggest improvement came from full management of the fuelling and ignition. A carbed Pinto shows obvious bore wear at 100k, even though it has an efficient and effective carburetor. I've taken heads off 175k injected Pintos that still had the honing marks in the bores.  And that's from a simple, single coil distributor based system that is both reliable and easy to diagnose if it does fail.
One thing that older vehicles did manage, albeit accidentally, was that the whole car wore out at roughly the same rate: a fifteen year-old rotbox with a tired drive train and worn interior needs no justification to be scrapped. Scrapping a more modern vehicle that could do the same again if it didn't need a clutch that's more than the value of the car(for example) is a poor design and use of resources.
« Reply #10 on: 28 December 2018, 13:54:59 »
Modern cars seem to 'stay in tune' far longer than cars of old.
Points would become pitted and close up. The ignition timing would slip and the car go slowly out of tune often without the driver knowing.
Much the same with carbs compared to fuel injection.
Plugs would often be tired by 6000 miles. As far as I'm aware they should be changed every 80,000 miles in the mighty Signum and 100,000 miles in the Indian.
« Last Edit: 28 December 2018, 13:56:48 by Field Marshal Dr. Opti »
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #11 on: 28 December 2018, 14:02:16 »
Back in the early 90's I sold my 1.4 Petrol Escort Van that had been all around the UK with 275K on the Clock back to Fords for a strip down.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #12 on: 28 December 2018, 14:34:20 »
My old Mk3 Grannie was 200k when it finally  got incurable rust syndrome. Guy who bought it drove home to Derby and transfered the engine into a `1940s retro car. Said the drive back was a pleasure. Was going to try and weld it but just too much to do.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #13 on: 28 December 2018, 22:36:02 »
Designed with fleet sales in mind. :(
  • Chatham, Kent
« Reply #14 on: 28 December 2018, 23:12:14 »
And it's mainly an oil and filter change; there's nothing to adjust on managed fuel and spark, or hydraulic tappets. That only really leaves a timing belt every fourth or fifth service, and how many company cars are kept that long? Even then, I can do the plugs, oil/filters and tappet adjustments on a OHV V6 in about the same time as the plugs, oil and filters on an Omega V6 simply because they're more maintenance friendly.
Things like plugs lasting longer is also largely down to them working in an optimised engine, rather than one that is a least-bad setup.
I've owned some real crap but haven't had to fiddle with carbs and distributors much. That's because I fix the problems rather than try to work around them. The biggest issues I've had have been with multi-carb setups: factory linkages tend to be shockingly bad, the linkage on the twin DCOEs on my Sunbeam was mainly designed to use the stock cable. Binning it for Weber's own linkage and cable, then adjusting it properly meant never having to adjust them again. Didn't jam open either :o . Unfortunately there isn't such a simple cure for multiple SUs, although on A-series engines replacing them with a single 1 3/4" HIF is a good bet.
