oil seal installer tool
Started by raywilb, 31 January 2019, 13:20:55
raywilb
going to renew the crankshaft seal (front). where can i get an installing drift ?? there are some kits on ebay ,but nothing when i specify 2.2 dti omega.
Migv6 le Frog Fan
shyboy
Are you using any magic technique for removing the pulley apart from brute force, and how are you locking the crankshaft?
raywilb
Quote from: shyboy on 31 January 2019, 14:47:24
crank sensor out , t.d.c insert locking pin (may have to turn crank slightly so the pin goes right in with no play on the crankshaft) advise to use new bolt. i have the locking gear for this engine.  :y
raywilb
Quote from: Doctor Gollum on 31 January 2019, 13:32:48
Suitably sized socket :-\
i would need a 68mm or thereabouts my biggest socket is a 36mm that i use for the oil filter housing.
Quote from: raywilb on 31 January 2019, 14:57:47
You're going to use the timing locking pin to loosen the crank nut :o  That's unlikely to end well......
raywilb
Quote from: Nick W on 31 January 2019, 17:52:30
having thought i explained that i am locking the crank with a crank locking pin . a 24mm socket on the bolt, breaker bar attached ( may need to slip a scaffold pole over the breaker bar ) having done 3 in the past i am sure i will manage. A new pulley was only put on by myself last summer. at that time the seal didnt appear to have a leak
raywilb
Quote from: raywilb on 31 January 2019, 18:50:38
Quote from: Doctor Gollum on 01 February 2019, 10:57:52
Quote from: Fuse 19 on 01 February 2019, 10:30:05
I probably have one :'(
Presumably from the train set...
the reason i really was wanting the proper fitting Drift is that spring on the inside edge of the actual seal are easily dislodged & once knocked into situ if the spring is dislodged one would be none the wiser & in a year or so the seal would start to leak again. the proper tool would alleviate that. but still cannot find one
Is the seal location a removable piece?
