Strange front track rod / toe angle goings on
Started by Webby the Bear, 11 February 2019, 15:56:45
Enceladus
Part number is GM 9195731. However I suspect that factory original is long obsolete and no longer available. So phone your local dealer and ask. Also factory was likely ZF but they don't seem to sell these in the aftermarket. Which probably means there are no ZF left.
dave the builder
if your searching for carlton ones,there are 2 different lengths available so be careful  :y
Quote from: dave the builder on 18 February 2019, 12:08:20
As there are for the Omega ::)
One is for power steering, tother isn't, and ultimately, 2mm is neither here nor there ;)
Enceladus
Power steering. Don't all Omega B have power steering? The only other idler for Omega B is 90305898. This is used with Y25TD, an engine option never available on RHD Vauxhall. It also has a different shape at the bush end.
Webby the Bear
Changed it tonight.
5 seconds with air hammer and it was off.
RIP Paul Lovejoy
dave the builder
Quote from: Doctor Gollum on 18 February 2019, 13:09:03
carlton senny idler arms come in 2 variant lengths  ::)
110mm AND 121mm
11mm makes a big difference if you fit the wrong one  ;D
Quote from: dave the builder on 18 February 2019, 19:40:49
110mm AND 121mm
I knew it had a 2 in it... :D
You could always fit the pitman arm to match ::)
terry paget
Quote from: Webby the Bear on 18 February 2019, 18:40:34
Changed it tonight.
You make it sound easy. Did you put a heavy hammer behind the taper?
Quote from: terry paget on 18 February 2019, 20:52:33
Changed it tonight.
It is easy. I've not needed two hammers for splitting trackrod ends for years. A good hard clout with one big hammer is enough to split joints that have been together for 40 years.
Webby the Bear
Changed it tonight.
No mate. No hammers used. The nut that secures it to the chassis came off easy. And then it literally slid off. The nut on the ball joint end was tight but then once off I got a stubby bit for my air hammer. Five seconds of dugga duggaring and it was off.
If I was to do it without the luxury of the air hammer I'd have got a drift and smashed seven bells out of it*. Access was a bit tight (hence the drift) but I didn't bother jacking it up removing wheels etc. so that would help.
One thing to note as with most ball joints on fitting the new one I had to jack up the bottom of it otherwise it would have just spun as I tightened the nut. Other than that it was straight forward 👍
*when I say id have smashed seven bells. I actually mean id have got young un to hold the drift while I swung at it. Do this if you're limited in hands. If not hold it yourself 👍
RIP Paul Lovejoy
Quote from: Webby the Bear on 18 February 2019, 21:39:41
Give the joint a healthy tap with your splitting hammer, then pull the steering to full lock and tighten the nut.
Webby the Bear
Whatever is ur preference mate 👍👍👍
RIP Paul Lovejoy
It doesn't always work, then you use the jack.
And if you're lucky enough to be working with a lift, using the jack isn't really an option.......
Enceladus
What is a "stubby bit"?
For the benefit of us all, where did you get the new idler arm from?
Maybe hang on to the old arm in case it can be sent somewhere to be polybushed?
