Strange front track rod / toe angle goings on
Started by Webby the Bear, 11 February 2019, 15:56:45
Webby the Bear
Fitted two front track rods from ATP (both inner and outer 'ends'). Tracked it up the same time I adjusted the camber. Took it out. Lovely.
Week later I noticed it was wandering/slightly unstable at 60-ish. Checked tracking. Front camber still bang on with 1' 10 exactly on NSF 😎 and 1' 15 on OSF. But front toe was out again.
Adjusted again to 0' 05 front toe. Again drove it on the dually and all good. Another week (maybe two actually) go by and I notice same slight instability. Pull it in yet again. Once again camber exactly as it was before, rear tracking bang on as I left it. But front toe out again 😧😧😧
These are, to TBs displeasure, ATP parts as mentioned above. I haven't hit any pot holes and I e done hardly any miles. Wtf is going on? I'm tempted to just get some genuine ones but I'm struggling to see how they keep coming out of alignment. Any ideas?
RIP Paul Lovejoy
Webby the Bear
Yeah tightened them up but I must admit they didn't feel very  nice. I have kept the old ones so I think I'll swap the clamp over for the old one as never had a problem with the old one.  :y
RIP Paul Lovejoy
Enceladus
The spec is -0°10' +/-10' toe-in. There is a GM TID advisory somewhere to increase the toe-in to the max limit, that's a total toe-in of  -0°20',   primarily aimed at reducing abnormal wear to the inboard edges of the front tyres.
AIUI the intent is to compensate for the 'give' in the wishbone bushes which can add toe-out when the suspension is loaded.
So in addition to anything else you choose to do I would add some more toe-in.
Webby the Bear
Thanks Encelidous.
TBH I'm completely happy with the OOF / WIM recommended settings. It's just that I set it and then it alters out of spec very quickly.
As said I'll put the old clamp back on and hopefully that'll sort it.
If not I'll try another set of track rods as they're easy to change.
RIP Paul Lovejoy
Also worth mentioning that the toe setting relies on exactly where the steering wheel is clamped, so might vary slightly from session to session.
Check if the total toe has moved rather than just left and right.
Webby the Bear
Thanks Kev.
Yeah that is true. It's just weird how it drives real nice straight after and then is well out a week or two later lol
RIP Paul Lovejoy
Webby the Bear
Getting all new tyres in March so want to get this sorted asap. Fekkin cars 😂
RIP Paul Lovejoy
terry paget
It's worth using a torque wrench on the track rod clamp bolts, 15Nm is quite tight. If loose they can rattle or drift out of setting.
Gray Fox
 ::)I think it's your arm bushing are gone. But what do I  know?  I'm from California
Webby the Bear
RIP Paul Lovejoy
Webby the Bear
Of course. Car on deck before using an actual torque wrench to tighten nuts/bolts to spec 😎😎😎
RIP Paul Lovejoy
Count yourself lucky you're getting 2 weeks out of ATP shite ;).
Actually, count yourself lucky they actually sent them.
Webby the Bear
To be fair mate while I've never had a problem before I doubt I'd be having this issue should I have gone genuine. Any other brands out there that do the full track rods? That's if I have no luck with swapping the clamps over?
Cheers.
RIP Paul Lovejoy
