Temperature gauges.
Started by robertstums, 16 February 2019, 18:51:05
robertstums
Hello there!
I am wondering which part do i have to replace in order to fix my engine temperature gauge on the speedometer and also the general outside temperature shown on display.
Thanks
Display temperature is a €5 sensor behind the bumper. May also be a wiring fault as the bumper loom does get the worst of salt, spray and muck...
Gauge temperature is a €5-10 sensor which bolts to the coolant bridge. Again this might simply be that the spade connector that locates onto it has simply slipped off... Check this first. Do not confuse this with the ecu coolant temperature sensor with a Bosch plug.  :y
Also, if you ground the blue wire that goes to the engine temp sensor, the gauge should go to fully hot  :y
zirk
#3
Quote from: zirk on 17 February 2019, 15:44:55
Quote from: Doctor Gollum on 16 February 2019, 19:48:43
Euro's ? and theres me thinking Brexit was just around the corner
It is 8)
But OP is in Latvia  ;)
zirk
well I managed to bugger that modification update up then.   ;D
Rods2
#7
This photo might help you to locate the engine coolant temperature sensor.
robertstums
Thanks for all the answers and help, it really means a lot! I'm going to give it a try when i have some spare time.
