Mighty Signum fails MOT.
Started by Field Marshal Dr. Opti, 27 March 2019, 16:43:23
The good news is the test only cost £29.95.
Car failed on broken coil spring (again).... :-\
Both rear brakes excessively binding ......2.5 hours of labour.
Total £133 plus VAT......so £160.
Could be worse. :y Could be better. :-\
Rear brakes will be the handbrake self adjusters seizing within the callipers...
And I very nearly suggested a broken spring or two earlier ;D
Like you said, could be worse... at least it doesn't need welding ::)
Quote from: Doctor Gollum on 27 March 2019, 16:54:48
Advisories were both rear tyres having cracked tread in the centre.
Exhaust also got a mention but then it is the original from 2007. I imagine a replacement could cost a few bob.
Also......offside front ball joint has slight play.
Coil springs seem prone to breaking on a regular basis.
henryd
Quote from: Field Marshal Dr. Opti on 27 March 2019, 17:09:01
Is that because you are a lard ass and subjecting them to extra load ?!!!
other rides
Migv6 le Frog Fan
Or all the bouncing up / down with sil in there.  ;D
Viral_Jim
It's only to be expected really, given the raw sexual magnetism of that fine automobile
Quote from: henryd on 27 March 2019, 17:15:17
I still enjoy the physique of a sinewy youth........by that I mean.......oh, never mind. ;D :D
Quote from: jimmy944 on 27 March 2019, 17:21:36
Yep.....it's a babe magnet. :y
........much like an electric Golf. :)
dave the builder
#9
Congratulations on the fail  ;D
(or should that be, congratulations on the relatively cheap cost of getting it to pass after the fail)
can't be that many left , bit like Omegas  ::)
BazaJT
Yes but not many left in the case of the Signum can only be regarded as a good thing :D
Quote from: BazaJT on 27 March 2019, 18:17:40
.......Not many Signum's in sunny cunny. :y
dave the builder
"beauty is in the eye of the beholder"
here you go Opti clicky
The Signum will soon gain classic status.... :y
Snap up the remaining few while you can....disbelievers. :)
 ......obviously not the derv crap. They are worthless. 8)
