No instant gasket
Started by biggriffin, 29 March 2019, 18:26:55
biggriffin
Hoof'land storeman.
Bigron
British motorbikes could have done with that back in the day.....
Ron.
biggriffin
Ive watched quite a few times,, and still find it brilliant...
Hoof'land storeman.
For the next trick - Google up a video of "wringing" gauge blocks together..
If you want another tease - blocks of metal so finely ground that if you slide them together with nothing between them, they stick to each other. Magically. (No, not magnetism)
Quote from: aaronjb on 29 March 2019, 20:51:13
Nope air pressure, surface tension and molecular interaction .... no magic whatsoever .. pure physics ..  :)
It's high quality ground surfaces that are then lapped flat. A process that's simple in theory, but tricky(and therefore expensive) to get right
Quote from: Nick W on 29 March 2019, 23:52:06
Which is why I don't have a set of gauge blocks .. I'm too tight to pay for a set! :)
Bigron
Ah, gauge blocks - that's the term I was looking for! A colleague in the Mechanical Department at college once took a pair of those blocks and "screwed" the faces together, eliminating all of the air between them, and challenged me to separate them.
Could I buggery!
I can't actually remember how he got them apart.....
Ron.
I'd call them slip gauges  :y
You just slide/twist  them apart
Quote from: Andy B on 30 March 2019, 14:11:25
Have any slipped out of the door? ;) ;D
If I had the time (and inclination) I'd keep an eye on the car boot sales for stuff like that..
dave the builder
A pair of 7 n/m breeze blocks provides sufficient datum surface to  work on them french cars  :P  ;D
