Author Topic: any experience with fibre broadband to property?  (Read 9019 times)
jonathanh
  • coventry
« on: 03 April 2019, 10:43:26 »
I am supposed to be upgraded due to the current network only supporting about 1mps with a following wind and guess what they are planning on FTTP.  So far we have fibre to the end of the drive so the next challenge is to get it to the house - 150 metres away from the road.  I think the options are
1. dig a duct in: will take me 2 days work and a bit of diesel and a lot of mess plus the risk hitting existing services or hand digging around them ( which I hate)
2. suspend the fibre from a pole - I don't like that because of the cost of the pole and it limits clearance for machines (I need to cover a field)
3. use one of these point to point internet thingies (Ligowave thingie...)  which is a couple of hundred quid and I have a convenient brick build meter cupboard to use near the road where the fibre arrives.
I'm thinking of going for option 3: cos I can fit pretty quickly and it saves a huge amount of disruption.
Any thoughts from the experts here?
thanks in advance
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Re: any experience with fibre broadband to property?
« Reply #1 on: 03 April 2019, 11:18:17 »
I thought the fibre went to the Openreach cabinet and then you use the exiting copper wires to get your service?
« Reply #2 on: 03 April 2019, 11:21:19 »
Not with FTTP - Fibre To The Premises - no. Fibre to your door and inside a Fibre->Ethernet converter.
Personally I'd suck it up and have the fibre run to my door, not the end of the driveway - do you want to be out there in your slippers and undies, rebooting the router when it (inevitably) crashes at 10pm on a rainy winter night?
jonathanh
  • coventry
« Reply #3 on: 03 April 2019, 11:35:55 »
fair point on the reboot.  I must put that in the au pair's job description.  Its just a real pain digging 140 metres of red clay up... do it in the winter and it claggy, the summer is rock hard...
« Reply #4 on: 03 April 2019, 11:46:01 »
Get the Au Pair to do the digging too  ;) ;D
« Reply #5 on: 03 April 2019, 12:34:24 »
....breaking off every hour to give you a blow job  ;D
    • E250 Est / Elroq
« Reply #6 on: 03 April 2019, 12:47:46 »
How does the current phone line get to the house, They will normally mirror that run, although I found they were happy to run the fibre to a different room then the phone cable.
Im my case Phone line was from pole to right side of house. The fibre comes to the same place on the top of the house initially but they routed the fibre to the left side room rather than the right like the phone cable
« Reply #7 on: 03 April 2019, 12:48:15 »
Is said point to point Ethernet thingy capable of operating over the expected temperature and environmental conditions associated with a dodgy brick cab by the road?
jonathanh
  • coventry
« Reply #8 on: 03 April 2019, 12:58:57 »
current phone cable is buried about 9 inches below the surface in a field - I'm not at all fond of that because I want it deeper and that's a lot of digging even with a 1.5 tonner
jonathanh
  • coventry
« Reply #9 on: 03 April 2019, 13:04:03 »
I've not studied the Ethernet thingie in detail about temp and environmental conditions.  The brick cab by the road is mine: contains single phase and three phase electricity supply (de-energized) is secure and dry now given I fixed it.  is there something I should be worried about?
    • E250 Est / Elroq
« Reply #10 on: 03 April 2019, 13:06:58 »
Is it in a duct?  Fibre is usually blown along ducts so they may well be able to utilise that.
jonathanh
  • coventry
« Reply #11 on: 03 April 2019, 13:18:28 »
sadly no - no duct used in 1964 when the chucked the cable straight in the ground
« Reply #12 on: 03 April 2019, 13:35:36 »
Well standard products are rated to a very low IP rating and 0-70degC if your lucky.
Given the location you will need better IP and wider temperature range as a minimum
jonathanh
  • coventry
« Reply #13 on: 03 April 2019, 13:42:36 »
incredibly useful thanks - I had not studied the products in detail so yes not looked at temperature and IP rate.  i'll do a bit more digging on both but it sounds like, provided I can get suitable kit it is the way to go
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #14 on: 03 April 2019, 14:01:00 »
We've got virgin, and that comes straight underground from the box on other side of the road, into a junction box then into the router.
Hoof'land storeman.
