Can the alloy HP air con pipe be compression fixed
Started by Andy A, 07 April 2019, 19:55:54
Andy A
My Sons partners Nissan Note 2006 manual was in an accident and the alloy HP hose has snapped off at the dryer end right next to the rad. If I get another dryer connection part of the pipe from a scrapper can they be joined together with a compression fitting?
Thanks
biggriffin
Yes,  as long as it's gas tight, trucks run 8-10bar and when a pipe splits/brakes brass compression fitting are used. Always wondered could you use compression fittings..on aircon.
Hoof'land storeman.
Andy A
Quote from: biggriffin on 07 April 2019, 20:38:19
Thanks biggriffin. Managed to pick a complete pipe up.  :y
