Author Topic: Where can I get an adaptor  (Read 2491 times)
« on: 22 August 2008, 12:22:42 »
I need a mains power adaptor, capable of pushing out 13.5 volts and 0.5amps.
Any idea where I could get one, maybe a universal one? ::)
Even Maplins couldn't help  :'(
jimmas
  • stevenage, herts
Re: Where can I get an adaptor
« Reply #1 on: 22 August 2008, 12:27:21 »
not sure but I think maplins sell adapters.
jimmas
  • stevenage, herts
« Reply #2 on: 22 August 2008, 12:27:58 »
sorry just seen you have already tried maplins  :y
« Reply #3 on: 22 August 2008, 12:28:26 »
So, regulated or unregulated.
DC or AC?
What is the application?
« Reply #4 on: 22 August 2008, 12:28:29 »
My big one is maplin, upto 12v at 1a, not sure they went bigger
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« Reply #5 on: 22 August 2008, 12:29:27 »
Have you looked on ebay another option is maybe a model shop does it need to be 13.5v you also need to know if it is ac or dc output
LFF64
  • HADDENHAM BUCKS
« Reply #6 on: 22 August 2008, 12:31:34 »
RS components or farrnell but you need an account set up unless your near a trade centre They may deal direct with the public
« Reply #7 on: 22 August 2008, 12:31:45 »
Not sure without looking it up somewhere, but, it's for my Halfrauds 300 powerpack/inverter, if that helps?
« Reply #8 on: 22 August 2008, 12:34:50 »
13.5 volts is an odd supply voltage and not standard (the standard is 12 and 15V).
Any info in the instructions as to the input supply range?
CPC do a couple of switch mode supplies with 13.5V outputs
http://cpc.farnell.com/jsp/search/browse.jsp;jsessionid=HL4FYLLWJFYIUCQLCIQJLTQ?N=411+1002145+500001+114087&_requestid=79559
« Reply #9 on: 22 August 2008, 12:35:55 »
ANother option would be to get a 15V supply and put a couple of rectifier diodes in series on the output to drop the supply by 1.2-1.3V to give 13.7/8ish
« Reply #10 on: 22 August 2008, 12:36:15 »
Unfortunately not Mark, All I seem to have is the powerpack. The charger and book has been lost  :'(
« Reply #11 on: 22 August 2008, 12:38:52 »
I suspect that there is little in the way of internals to the battery pack regarding the charger circuit.
You could knock something up with an L200 (or similar) reg to provide 500mA current limit and 13.5V voltage regulation I guess....requires a bit of very basic electronic design though.
« Reply #12 on: 22 August 2008, 12:52:26 »
I just called Halfrauds Tech support, they can get me a new charger for £15. Bargain :D
« Reply #13 on: 22 August 2008, 12:58:08 »
I was going to say, the other option is that Halfrauds sell trickle chargers in the form of a mains adaptor. Could always buy one of those and chop the crocodile clips off and put a jack plug on.
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #14 on: 22 August 2008, 19:55:43 »
You do not need an acount at Farnell & can pay by credit card
(CPC are also a Farnell company)
