Fitting a Y32SE to a 1972 scimitar GTE.
Started by MikeyBikey, 09 June 2019, 17:35:06
Keith ABS
Quote from: Doctor Gollum on 28 September 2023, 19:41:16
Quote from: Keith ABS on 28 September 2023, 19:28:14
I have an R28 from a Carlton/Senator for sale
If you were going to scrap it anyways... >:D
Part of a full minibus full of parts I collected for ABS
MikeyBikey
So the first R28 gearbox we've pulled apart has buggered synchro's on Reverse and 5th.  Bearings are ok, but if we need to replace, they're not currently listed anywhere.... Might be able to find alternatives. Oil seals would be required as well....
I was trying to avoid changing gearboxes as a lot of effort was put into the Red top flywheel, clutch and concentric slave set up to get it working correctly.
But at the mo the gearbox in the car is properly dreadful and i've got two broken ones. It might be a case of trying to build One from the Three.
regards
Viral_Jim
If you need to replace the bearings at any point. Try these guys, they've always been extremely helpful, even with really obscure stuff like phosphor bronze bushings for a 1980's cement mixer  ;D
https://simplybearings.co.uk/shop/index.html?currency=USD&gclid=CjwKCAjw1t2pBhAFEiwA_-A-NJLvtNhETJOzXRdEJLo3tixQshIN_d8w0etE27EfZ7qqmQZeqoSqhxoCRUwQAvD_BwE
MikeyBikey
Quote from: Viral_Jim on 24 October 2023, 12:41:49
Brilliant, and thank you
MikeyBikey
So I have been previously told the GM R25-R28 gearbox is a Getrag 240 box and so is the Ford MT75 but in a different casing. The casings certainly look similar, but two gearboxes companies have today told me they don't think they are the same ?
Does anyone on here have a definitive answer please ?
regards
MikeyBikey
Quote from: MikeyBikey on 24 October 2023, 17:08:40
regards
And a couple of questions.
Do other Omega gear boxes fit the V6. ie is the bellhousing bolt stud pattern similar on any others.
Are any of the synchros on say other omega gearboxes match the R25-28. My gearbox man thinks he can build a box up from bits. Just syncros are the issue. I need synchros on reverse and 5th. I potentially have a spare but not sure. Just wanted to ty to maybe get another or suitable spares.
MikeyBikey
Basically the petrol derivatives appear to have a consistent bellhousing bolt pattern 1.8, 2.0, 2.2, 2.5, 2.6, 3.0 and 3.2
