Pages: 1 2 3 4 5 [6] 7   Go Down
Author Topic: Coolant leak  (Read 34900 times)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Coolant leak
« Reply #75 on: 12 September 2019, 18:34:34 »
Are we going to have the first confirmed case of hgf on a 3.2 ?
It wouldn’t be the first. Ask Rae turbo! His was so badly gone, that on turning over the engine, coolant came out of the spark plug holes  ;D
will we ever know though  :-\
that engine had been messed about with before (with added wood  ;D ),maybe miss-diagnosed head gasket was the reason it was messed with, then clearly not put back together very well until you got your hands on it James and sorted it properly
Re: Coolant leak
« Reply #76 on: 12 September 2019, 19:33:54 »
It had probably been in Cardiff Bay.
Re: Coolant leak
« Reply #77 on: 16 September 2019, 22:02:44 »
Coolant leak worse today, had my suspicions on the coolant tank for a while (it's on order) - Think this proves it....
All around underneath cap was soaking, I made sure it was nice and dry when leaving work after topping it up.
Re: Coolant leak
« Reply #78 on: 19 September 2019, 19:58:24 »
New coolant bottle did not solve the problem  :(
Re: Coolant leak
« Reply #79 on: 19 September 2019, 20:28:14 »
Did you bleed it properly?  ::)
Cap off. Fill header. Cabin temp on Hi both sides, fan Lo. Run engine until fans kick in. Burp hoses. Top up and repeat. Cap on tight. And call it done.
Re: Coolant leak
« Reply #80 on: 19 September 2019, 23:41:08 »
    • E250 Est / Elroq
Re: Coolant leak
« Reply #81 on: 23 September 2019, 06:36:08 »
I'm going to throw another one into the mix, as per my old blue prefacelift....weeping core plug.
From memory what you have is not far from what I experienced.
Re: Coolant leak
« Reply #82 on: 23 September 2019, 08:05:27 »
Thanks.  :y  How was it diagnosed/tracked down?
    • E250 Est / Elroq
Re: Coolant leak
« Reply #83 on: 23 September 2019, 13:45:10 »
Unfortunately, it was effectlively nothing else it could be.
Pressures tests all done, everything else ruled out.
Been to sleep too many times since to remember too much
Re: Coolant leak
« Reply #84 on: 23 September 2019, 15:04:19 »
No worries, one thing though, did yours suffer a miss-fire when cold?
Re: Coolant leak
« Reply #85 on: 23 September 2019, 15:48:49 »
This is heresy......  :o  So burn me at the stake by all means!  :)
But...  If you are convinced it is the head gasket.... and it's headed for the scrappy?  ???
You could chuck a bottle of K-Seal or similar in it.....   :-X  With a bit of thought and bodgery, it would be easy enough to bypass the matrix as well.  :y
Boom!  :o  There.... I said it!  :D  ;D
Re: Coolant leak
« Reply #86 on: 23 September 2019, 15:50:52 »
He won't have time for that...
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Coolant leak
« Reply #87 on: 23 September 2019, 16:22:38 »
Wondaweld would cure it * IMHO
coats everything in a sticky,rubbery shell.
I've used it ,car did 35k ,2 years ,then scrapped it for other reasons
* if used correctly ,empty and flush all coolant BEFORE treatment ,flush everything out well after and put the coolant back in
K seal has bits of copper that ,if lucky, may catch and plug the hole/fail , I'm not a fan
but if Tunnie intends to scrap it anyway ,wondaweld would be the way I would go , may give him another 2 years for £13 spend and a couple of hours work ,
Re: Coolant leak
« Reply #88 on: 23 September 2019, 16:51:36 »
Many moons ago I put radweld in one of my cars (I forget which) and forgot about it for the two years or so till I traded it. Cars were much more simple then, not so many things to get clogged by it.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Coolant leak
« Reply #89 on: 23 September 2019, 17:10:18 »
Ahh yes, one of the must have items in the Holts " Sell your car" kit, along with Gungum, Isopon and Tyre black.  ::)
Pages: 1 2 3 4 5 [6] 7   Go Up
Page created in 0.238 seconds with 20 queries.
