Vectra coolant leak
Started by terry paget, 22 September 2019, 13:48:00
terry paget
[/img]https://www.dropbox.com/s/ftc2fwijxqiuhw5/VECTRAleak2.jpg?dl=1[/img]
Vectra C 1.8 petrol manual
Found a puddle under this car this morning. Seems to be coming from a metal pipe beneath the thermostat, which then disappears behind the front heat shield. It's a simple joint, torx screws either end, got no excuse to leak now. Does anyone know, is it a flat paper gasket seal, or an O-ring?
terry paget
dave the builder
looks like a flat fiber gasket ,but ,as I said before(when you replaced the wet stat), the thermostat housing is prone to cracking
especially if any fixing is over-tightened
a smear of instant gasket on the old gasket should solve a leak from the gasket
it won't solve a leak from a crack in the housing
so examine closely ,torch and magnifying glass is a help  :y
Neither...
It's normal condensation from the aircon system. Ignore it and do something more important  :y
Quote from: Doctor Gollum on 22 September 2019, 14:05:14
Neither...
That said, if it's dripping down to that then it may well be the thermostat seal.
Neither...
Terry said he came out this morning to find a puddle.  An aircon condensation drip would have dried up overnight.  ;)
Quote from: Sir Tigger QC on 22 September 2019, 14:42:07
Neither...
Had a further look at the picture, hence my subsequent post :y
terry paget
Thanks for advice, gentlemen. Taste test confirms it is coolant.
Odd it should decide to leak after 11 years service; I reckon Dave could be right, that the housing has cracked. I see on e-bay I can get a thermostat for £15, or a thermostat with housing for £23. The housing assembly will involve more connections, but seems safer route to me. Any comments?
terry paget
www.ebay.co.uk/itm/FOR-VAUXHALL-INSIGNIA-1-6-VECTRA-C-SIGNUM-1-8-THERMOSTAT-WITH-HOUSING-SENSOR/251437585024
This thermostat and housing assembly has what looks like a coolant connection below the thermostat. I imagined it was an aircon pipe. It seems to go below the thermostat to connect with the heater input hose.
If so, that poor connection could be my coolant loss.
Quote from: terry paget on 22 September 2019, 19:52:59
If, as that link suggests, the housing is plastic, I would be inclined to change the whole assembly as the plastic is likely to be getting brittle, and therefore leaky :y
terry paget
The thermostat housing is indeed plastic, thus prone to cracking if screws are overtightened.
My theory is that the thermostat housing does not need changing. The leak is the junction between the heater pipe from the block at its connection to the base of the thermostat housing. Do you agree?
Not necessarily, that pipe flange could be below the leak...
dave the builder
Quote from: terry paget on 22 September 2019, 20:38:19
Quote from: dave the builder on 22 September 2019, 14:04:13
we can't remote examine where the leak is Terry
you can get the housing off and physically look at it  :y
terry paget
Or maybe you think that a crack in the thermostat housing is the cause of the leak in the heater pipe junction. So the cure is to change the thermostat housing.
