Service vehicle soon
Started by STEMO, 27 September 2019, 11:25:08
That's the message I'm getting when I start up my astra, so you'd think it needed a service, yes? No  ;D
Being experienced with these things, I know it needs a glow plug (about £130 on these  :(), so I'll wait till next service/MOT at the end of the month.
Now, whilst perusing the same model locally on the trader, as you do, I noticed that two out of the 16 available had the very same message. And they were the ones with the ignition on, others may have had it too. I wonder what tale these dealers will tell potential buyers, or even if the dealers are aware of what the message means.
When these 2.0 Vauxhall diesels get to around 50,000 miles, they tend to need glow plugs about once every six months, until you've replaced all four.
Another ballache would be the servicing garage charging me to read the fault as well, but my local usually doesn't, esp if I've already told him what he's gonna find.  ::)
Raeturbo
Wow £130 just for glow plugs. Is that for the 4 fitted?
Laying a rubber road.
Quote from: Raeturbo on 27 September 2019, 11:44:46
No, just the one. I gave him a funny look when he told me last time, but he showed the trade receipt from Autovaux.
They have a pressure sensor in them to monitor cylinder pressures, so quite pricey.
This is a common approach these days with multiple firings of the injectors every cycle.
Migv6 le Frog Fan
Think I have the same issue on Airfix 1. If the plugs are that pricey I shall ignore it until it wont start, then burn the fickin thing.
Quote from: Migv6 le Frog Fan on 27 September 2019, 15:31:10
The glowplugs for my Mondeo's transit engine were about £11 each IIRC.  :y
So a glowplug for a French tupperware car should be about 50p!  ;D
Quote from: Sir Tigger QC on 27 September 2019, 15:47:21
The glow plugs for my Astra G were about £15 each from Vauxhall, as were the glow plugs for my sister-in-law's Astra H but a neighbour had an Insignia and they were over £100 too .... we were surprised at the cost as they were being supplied by another neighbour who is also in the motor trade.
henryd
Quote from: Andy B on 27 September 2019, 15:52:04
Same engine as Stemo's I expect :-\
other rides
Quote from: henryd on 27 September 2019, 16:05:56
Do they shear as easily as Merc's slim line plugs do? I managed to shear one on my R Class using a 1/4" socket  ??? :(
Plugs are supposed to be changed at 80000 on the mighty Signum.
Front 3 are easy to get at. Rear 3 are a pain in the arse. Mileage is now 92000 but all is well so I'll follow the " if it ain't broke don't fix it philosophy" until I get a problem. :)
Viral_Jim
Quote from: Field Marshal Dr. Opti on 27 September 2019, 16:16:19
Leaving them doesn't knacker the coil packs does it? I know the DI packs on GM era Saab's can go bad with poor sparks being a contributing factor.
Quote from: jimmy944 on 27 September 2019, 16:54:06
I do hope not because there is an individual coil pack for each cylinder.  :-\
Plugs are supposed to be changed at 80000 on the mighty Signum. ....
were we not talking about glow plugs ... not spark plugs?  ;)
