Nord VPN
Started by Mr Skrunts, 04 November 2019, 14:25:55
Shackeng
Quote from: Eboy.com on 28 November 2019, 08:46:27
Quote from: Mr Skrunts on 27 November 2019, 23:12:41
Thought my acc had been cancelled.  Struggling on my phone but got back on.
My IP was blocked and access is denied. Could admin please unblock my IP caddy please.
TIA  :y
If you are using a proxy to access, well, TBH, it'll always get blocked. That's the nature of them.
If you're not, PM me your (blocked) IP, and I will see if its in our block list and remove if required.
Does this mean I won't be able to access OOF via a VPN?
Quote from: Shackeng on 12 December 2019, 12:47:20
TIA  :y
Depends....via VPN theres a fair chance you'll (try) to come in via a blocked IP and therefore wont get access.
Same for any site that utilises blocklists.
No problem via PIA (using any of the egress points I tried) :y
Also recommend PIA (Private Internet Access)  ... it's up and running as I type .. :) telling the world I'm somewhere in Germany at the moment !!
Is the weather any better?  :D
Quote from: Doctor Gollum on 12 December 2019, 15:12:51
Is that the "proxy" weather ... or the "poxy" weather (which is crap here !!   :)
The proxy...  ;D the poxy weather here is diabolical...
Trouble with proxies (including VPNs) is you're sharing IPs with a much higher percentage of dodgy people, and thus far more likely to end up on IP block lists.
