Pages: 1 [2] 3  All   Go Down
Author Topic: Hi all In trouble already.  (Read 10371 times)
Enceladus
  • London
Re: Hi all In trouble already.
« Reply #15 on: 02 December 2019, 22:49:30 »
You also need to find out why the spanner light is on. Try the pedal trick and report back the codes.
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« Reply #16 on: 03 December 2019, 07:44:15 »
I had something similar and had to change the whole selector, cleaning did not help as one (or some) of those leading metal sheets inside were totally cut.
https://www.omegaowners.com/forum/index.php?topic=119060.0
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #17 on: 03 December 2019, 14:13:25 »
Pedal trick doesn't work on the 2.2 IIRC , no idea why  :-\
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #18 on: 03 December 2019, 17:50:44 »
Do try and keep up omegod ::) the op has previously had a 2.2 but now has a 2.6 with which he's having the problem :y
gavlar001
  • kent
    • omega 2.6 mv6
« Reply #19 on: 03 December 2019, 18:11:54 »
Hi everyone ive been out to the car and cycled the gear selector back and through the range 6 or 7 times slowly and between D and N the yellow selector lights flicker for a second or so.I also hooked up a Autel canbus code  reader and read the codes it was showing zero.But i noticed the orange spanner light was not on the dash anymore but i guess i need to take it for a drive and see.
« Reply #20 on: 03 December 2019, 18:14:54 »
I'd be surprised if your code reader will read gearbox codes  :-\
gavlar001
  • kent
    • omega 2.6 mv6
« Reply #21 on: 03 December 2019, 18:19:57 »
Yep didnt think of that i suppose if it was hooked up to Tech 2 you would see it.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #22 on: 03 December 2019, 18:54:24 »
Depends which Autel he has. Our Snap-off kit won’t communicate at all with my Omega 🤣 Both my Autels will. I have one that just does engine and the other does engine, transmission, abs and srs 😃👍
RIP Paul Lovejoy
gavlar001
  • kent
    • omega 2.6 mv6
« Reply #23 on: 03 December 2019, 19:09:05 »
Just taken it out for a quick drive autobox was working as it should no orange light on the dash it must be that gear selector switch on gearbox.It was smooth in D and kickdown worked fine.Still no heat and temp gauge flat zero.
gavlar001
  • kent
    • omega 2.6 mv6
« Reply #24 on: 03 December 2019, 19:15:01 »
Autel is a AL 301
Webby the Bear
  • Northampton
« Reply #25 on: 03 December 2019, 19:28:44 »
Looking at that it’s just a code reader for engine. No live data function either. Don’t think you’ll get GB codes from that, only engine  :y
RIP Paul Lovejoy
gavlar001
  • kent
    • omega 2.6 mv6
« Reply #26 on: 03 December 2019, 19:42:14 »
Yep your right as ive just been out in it again.There was no orange car spanner on dash but Traction control and the orange spanner both came on at the same time permanently.
gavlar001
  • kent
    • omega 2.6 mv6
« Reply #27 on: 03 December 2019, 19:56:11 »
Have read in another thread of someone having a similar problem and having TC light and Spanner orange car light come up due to that switch.Also if you gently push left or right the fully lit yellow gear indication lights all go out if its in drive.What grease should you use to put back in it when its clean.
gavlar001
  • kent
    • omega 2.6 mv6
« Reply #28 on: 10 December 2019, 18:40:07 »
Does anyone have a gear selector unit for a 2.6 v6 sale will pay paypal.I have not looked at the unit yet as the weather is terrible and ive got no cover.Temp gauge has started working again risen up to 92 ish blew hot air for 4 mins then stopped.Pm me if anyones got one Thanks Gavin
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #29 on: 10 December 2019, 21:07:47 »
I may be wrong but I think you can put a 'Wanted' ad in the Test Area (but not a for sale ad) and if the Admins see fit they will move it to the Parts Wanted and For Sale area. (Due to post count rules you can't sell yet, but I'm sure you can ask for something). Specify 'Wanted' at the start of the ad.  :y
Just thought it may get a bigger audience that way.  :y  You can remove the switch and then clean it in the dry, or replace it, but unfortunately you'll still get wet whichever way you choose.  :y
« Last Edit: 10 December 2019, 21:11:52 by YZ250 »
Pages: 1 [2] 3  All   Go Up
Page created in 0.012 seconds with 15 queries.
