Author Topic: Can you adjust  (Read 1728 times)
Can you adjust
« on: 28 August 2008, 20:26:12 »
the accuracy of the pointer on your computer, mines a good 10mm out and its begining to pox me off >:(
Re: Can you adjust
« Reply #1 on: 28 August 2008, 20:30:31 »
Very bizarre!
Have you tried unplugging and reconnecting?
Control Panel, Mouse is all the options you get, and not normally any calibration apart from double click speed etc
Re: Can you adjust
« Reply #2 on: 28 August 2008, 20:32:03 »
Ive been through the mouse settings on the control panel, I'll try unplugging ;)
stuart30
Re: Can you adjust
« Reply #3 on: 28 August 2008, 20:32:07 »
Do you use a wireless mouse....if so check the batteries,if mine are low on power it buzzs about and is a right pain too use.
Re: Can you adjust
« Reply #4 on: 28 August 2008, 20:33:31 »
No just a normal one. I have to careful with the smilies  >:( oops ::)
Plomien
  • Swansea
    • Landrover Freelander TD4
Re: Can you adjust
« Reply #5 on: 28 August 2008, 20:40:45 »
sounds like the mouse has been dropped and the optic sensor has been knocked out of alignment.
See if you can borrow another mouse to confirm it.
If it works then time to buy a new mouse, if not then it could be a port issue, I assume you are using a PS2 slot try going through a USB again see if the same happens
Albert1
  • Herts
Re: Can you adjust
« Reply #6 on: 28 August 2008, 20:43:38 »
Clean the breathers, or if that's been done already then do the paperclip test.
Pete Elite
  • Uxbridge, Middlesex
Re: Can you adjust
« Reply #7 on: 28 August 2008, 21:05:12 »
  If it's the one with the rubber ball in the bottom Pete, try taking it apart and cleaning all the crap of the bars that have the wheel on the ends.
Re: Can you adjust
« Reply #8 on: 28 August 2008, 21:06:44 »
Lol.....it wont be mouse specific.....how can it be....the pointer is on the screen and its not pointing at the bit its activating so it MUST be software.
The old trick was to unplug the mouse and keyboard and let it boot....then plug the mouse and kyboard back in.
Re: Can you adjust
« Reply #9 on: 28 August 2008, 21:06:56 »
Its an optical one, came with the new Dell tower and its been like this for weeks. I think i'll go and buy a new one, there cheap enough.
Cheers Everyone :y
Re: Can you adjust
« Reply #10 on: 28 August 2008, 21:07:38 »
Maybe I wont go and buy a new one just yet ;D
Re: Can you adjust
« Reply #11 on: 28 August 2008, 21:08:15 »
Using std mousepointers, or a themed set?
Re: Can you adjust
« Reply #12 on: 28 August 2008, 21:09:05 »
Standard arrow
Re: Can you adjust
« Reply #13 on: 28 August 2008, 21:09:10 »
Lol, I cant beleave that people think its the mouse.
All the mouse does it tell teh compute to move the pointer in a directiona dn at what speed.....its got no impact on the relationship between the end of the pointer and the bit activated!
Note also, its a common Dell fault apparantly!
Re: Can you adjust
« Reply #14 on: 28 August 2008, 21:11:30 »
Its not the mouse.  It could be corruption in the pointers graphics, driver, or software if its specific to 1 app.
