If you think you're having a bad car day...
Started by aaronjb, 19 December 2019, 10:23:28
Apparently this was brought in with the description "The engine died at 70 on the motorway"
Yes, that's a sump full of pistons and rods.
No, all the garage did was take the sump off and find that (after they noted the big holes in the block)  :o ;D
Varche
Fantastic. There must be a few bits there that could be expertly repaired ( The Repair Shop maybe?)
I'll bet that made a noise when it let go.
Quote from: STEMO on 19 December 2019, 11:13:45
I'll bet the racket it would have been making before it let go was even more impressive!
iansoutham
Quote from: iansoutham on 19 December 2019, 12:41:04
What car?
MINI - I assume with the N14/N18 Peugeot/BMW Alliance engine.. at least it was in a MINI group, so I assume that much  ::)
Quote from: aaronjb on 19 December 2019, 12:42:10
What car?
Is that the MINI/BMW engine in SWMBO's 1600 twin cam petrol Citroen?  ???
Migv6 le Frog Fan
Looks like someone slipped it into 1st gear at 70 on the motorway.
Quote from: Migv6 le Frog Fan on 19 December 2019, 13:24:17
I managed to put a Sierra Sapphire into 1st instead of 3rd at around 50/55mph ..... fortunately it was a hire car!  :)
Quote from: Andy B on 19 December 2019, 13:20:05
What car?
That's the one.. known for eating timing chains, valve stem seals, valve guides, coking up the intake tract because it's direct injection so the intake ports & valves need walnut blasting every 40k, awful PCV setup, high pressure fuel pump dies every 70k, etc etc.. other than that it's a great little engine ;D ;D
Quote from: aaronjb on 19 December 2019, 14:10:22....
Oh!  :o I wish I'd not asked now! Ignorance is bliss as they say!
Hers is a 60 plate and around 35k miles IIRC, apart from a new ......
water pump,
'thermostat' (it's actually a motorised ECU controlled valve)
oil leak from the solenoid feeding oil to the variable cam,
temp sensor - there's a mod for that,
cam sensor
it's an auto but stalls when cold at the same place every time when she's off to work - restarts OK & is OK then all day.
  Citroen will replace 2 solenoids in the g/box for £600 plus to fix  ..... she lives with it  ;D
other than that it's a great little car  ::) ::) ::) ::)
I buggered up the 'fan belt' drive to the water pump cos I didn't know the set up ..... that was another £few hundred  :-[
Oh yes, the water pump drive is interesting, isn't it! Does nothing until the ECU tells it to start driving the water pump.. I've done the timing chain, accessory belt, valve stem seals, PCV, rocker cover gasket, plugs; I had the garage do the water pump (because I was in Seattle at the time, so a bit hard to do it from there ;D) the transfer pipe across the back and the "thermostat" all at the same time (made sense)..
There's an oil leak from around the vacuum pump (common fault) as well that I really must look at, but is currently fairly minor.. it's also an auto but so far doesn't stall ;D
It was either the MINI or a DS3 .. but since they share an engine, it didn't really matter which pile of trouble she brought home for me to fix ;D
YZ250
I'm familiar with that sight from my Ford hooning around days many moons ago. My experience was usually a misfire, followed by a metallic screech (as it seized up), a clattering as the con rods bent and then sheared the skirt off the piston and clattered in the bores. The slapping about shears the main bearing end of the rods and you are left with the mess you see before you. The rods that hang on punch a hole through the bore. My Pistons were still in the bore.
Back in those days you always had a spare engine sat in the garage for such occasions as this, as nobody ever notified DVLA of an engine change.  :)
Quote from: YZ250 on 19 December 2019, 14:57:38
Do they these days then?  ;D
