Gearbox issue HELP | i10 sticks in 3rd gear . .
Started by Alnico Blue, 28 December 2019, 14:14:38
Alnico Blue
Any advice gents  . . . hyundai i10 2011.   SWMBO  had to put on brakes sharply. .  .since then car gets to 3rd gear and shifter will not come out of 3rd to select another gear .
On the driveway all gears are selectable with or without engine running.
Pull away  . . .go through 1st & 2nd then straight to 4th  .  .all ok  . .then to 5th all OK.
As soon as 3rd is selected with the car moving it will not come out of 3rd. Even stopping and turning engine off it is still jammed.   Once in this jammed position the only way to get it to release is to slightly rock the car forwards or backwards , just a tad then gear shift moves out of 3rd  ok.
Gearbox oil is correct &  to the right level .
I feel it is not a linkage issue as all gears are easy to find when stationary ,The problem happens as soon as 3rd is selected with the car moving . the selection of 3rd when moving feels ok and smooth & no different to selecting other gears .
Strange this  . . .  any gearbox specialists out there to advise or suggest  as cannot see anything on any iternet forums etc. pointing to thuis issue..  thanks,   Al :y
British made Celestion Alnico Blue = best sounding guitar speaker ever, sadly now made in China
Alnico Blue
Quote from: Doctor Gollum on 28 December 2019, 14:24:18
New cables ;)
Is that a known cure for this sort of issue Doctor ?
We have tried to move the levers on top of the gearbox that the cables connect to by hand and lever , Just seems stuck fast until we rock the car  . . then it moves fine  ::) ::)
Cable adjustment might cure it, but basically the selector locks because it's trying to do two things at once. If it's done some miles it could be a gearbox wear issue, but you would expect other symptoms.
Have SWMBO run through the gears (engine off) whilst you watch what happens. All should be revealed... ;)
Alnico Blue
#4
Quote from: Doctor Gollum on 28 December 2019, 14:35:44
OK  Doc    will do  . . . .Thanks  :y      mileage is 74000  no guidance in Haynes on any sort of cable adjustment either.
I seem to recall that the i10 from around 2010ish does seem to shag gearboxes towards 100k.
henryd
If all the other gears engage and disengage normally I would think the problem is within the gearbox itself,normally a cable issue will affect more than one gear
other rides
Quote from: henryd on 28 December 2019, 16:53:35
This^
Alnico Blue
update:   yep gearbox shagged . . .74k miles . . .    got one from a 2013  model with 35k on it.
Was gonna try new cables first but  "The Hyundai spare part price list" seemed to have a decimal point in the wrong place  . . .£208   for a pair of cables 60cm long  with a small bracket attached :o :o
New clutch and box and an O/S front wheel bearing  fitted yesterday  . . .car drives so much better.
Swmbo loves  it now  :y :y :y.   ( BTW   N/S front wheel bearing was done just before I brought the car)
thanks for your advice OOFERS  :y
The gearbox does seem to be a weak point on them, set to fail just as the 7yr/70k warranty expires.
Shame, as otherwise they seem a robust enough car, perfect for round town, albeit a of a bit bland drive.
There is a lot more than the gearbox falls off a cliff after the 7 year warranty sadly.
Alnico Blue
Quote from: Fuse 19 on 07 January 2020, 07:30:38
I spoke with quite a few owners before I got this for SWMBO . . .they all seemed impressed  . .
Maybe they were reluctant to admit that they also should not have brought one !
Parts prices are shocking !      I want to move it on  . . .but SWMBO loves it now
I wonder what the next major failure will be  :'( :'( :'( :'(
Quote from: Alnico Blue on 07 January 2020, 19:17:03....
Parts prices are shocking !       ....
We found that years ago when SWMBO had a Lantra
..... cheap cars made from expensive parts!  ;D ;D
The secret with cars that have seven year warranty is to sell/trade them after six.
Quote from: STEMO on 07 January 2020, 21:01:17
the cars are at worst OK, and are improving.
they're cheap to buy new, and are generally reliable(far better than any European marque)
routine maintenance is cheap
They're not worth much when the warranty runs out, but you'll still have lost less than an expensive car with better residuals. And those don't have 7 year warranties, so you hit the costs sooner
So you have the usual two choices: keep it until it needs an expensive repair, or trade it in for another. Your own preferences for expenditure and knowledge of how stuff lasts for you will make the decision.
Hyundai/Kia(which are very closely related) parts do cost a bit more than you would expect for the cheaper end of the market, but anyone who has priced Mitsubishi or Honda parts will laugh at you if describe them as expensive.
I'd be looking at any of the small to medium cars first, if I was going to buy a new car. Cars are tools, and all of the pretentious marketing wank from the long established names is an expensive and tedious cost I could do without.
