Slight judder on pulling away in Vectra
Started by terry paget, 29 December 2019, 15:30:13
terry paget
2008 Vectra 1.8 manual petrol
As title, judder on pulling away. On earlier cars this was caused by soft or loose engine mountings. I have not known it recently on any other Vauxhall, either FWD or RWD. Any thoughts?
Sticky release bearing or faulty clutch hydraulics ;)
What does the brake fluid look like?
terry paget
Brake fluid doesn't look too bad, not cloudy. I only bought the car in July, I've not changed it yet. I would not have thought changing the brake fluid would do much for the fluid in the clutch, I have never changed the clutch fluid as a maintenance procedure, I only bleed the clutch after a change of clutch master or slave cylinder.
It's the same fluid whether you change it or not ::)
But if it looks pretty reasonable, then it's probably not that. Hydraulics can fail and clutch wear can cause a build up of dust on the splines and release bearing causing stickiness.
Any noise/harshness from the clutch when applied in neutral?
terry paget
Come to think of it, I suffered a similar phenomenom on face lift Omegas with electronic throttle. Throttle response was so instantaneous car acceleration would rock me back a bit in my seat lifting my foot off the throttle pedal, so feedback judder. Not felt it on the Astras, though. Thanks Doc, food for thought. Furthermore, the clutch disengages wih the pedal pressed hard on the floor, so might help bleeding the clutch anyway.i
Keith ABS
henryd
other rides
terry paget
Just to put it in context - this is not a bad judder, I have known worse. When I bought the car last summer I gave it a road test first and noticed nothing wrong with it. Two of my sons have driven it in the last two months, and they liked it, preferring it to their Astras.The clutch does not slip. It does disengage cleanly, but when only with the pedal fully depressed to the floor, more so than the Astras.
50 years ago I had a Ford Escort with a bad judder, but that turned out to be a soft engine mounting. I appreciate that the clutch splines might get sticky with accumulated dust and this could cause judder.
Your supposed to fully depress the clutch...
Not doing so would cause judder and accelerated wear. Which might explain your symptoms  :-X
terry paget
Quote from: Doctor Gollum on 30 December 2019, 15:07:53
You're right, Doc, Now I suspect the problem is how I sit in the car. My left shoe ( I wear wide metal soled and toe-capped shoes for comfort, old feet, corns, etc.) fouls on the body below the heater in the Vectra, causing incompete clutch depression. This does not occur in the Omega or the Astra.
BazaJT
Your trouble is you've got one too many pedals in your cars ;D ;D
dave the builder
Quote from: BazaJT on 31 December 2019, 17:48:44
No ,Terry's cars have 3 pedals  :-\
as God intended  ;D
BazaJT
Clearly God intended cars to have the proper number of two pedals hence only giving us two feet.Some joker then tried to confuse things by fitting a totally unnecessary third pedal :o ;D ;D
