WTD: Rear subframe donut bushes for '01 2.6 estate..
Started by JDX, 05 January 2020, 10:02:44
JDX
...the car failed it's mot  :(
Am therefore in need of these bushes - anyone?
I've seen the maintenance guide & there is a picture of poly bushes used & it seems logical to me to use them whilst I'm at it!
Anyone know where I may get these from?
Thanks.
biggriffin
 Polys about £100,, rubber from eBay about £30.
Hoof'land storeman.
Assuming doughnuts, and not diff mounts, then PM YZ250, I think he has a set of polys to sell.
Quote from: Eboy.com on 05 January 2020, 11:39:43
knackered or at least very tired, diff mounts should also be expected and it would be worth inspecting them before starting the job. Then you can factor in the turnaround time on a pair of repaired mounts......
JDX
Quote from: Nick W on 05 January 2020, 11:53:48
Oh dear, now I'm not sure...this is what the mot fail says:
"Nearside rear sub-frame rubber bush deteriorated resulting in excessive movement (2.4.G.2)....same for the offside!
amba
Ive often wondered how the "mot man" really checks them as they are virtually hidden inside a metal cup and the only bit is the outer lip which will always appear rusty as its just the cover plate.
If the thing flaps around then its clearly failed but even then it would hardly give." excessive movement".
Sounds to me like subrame donut bushes though ...about £20 each and around hour a side ..if they aren't totally seized in .
JDX
Quote from: amba on 05 January 2020, 14:02:03
Thanks....yup, I agree - looking at how they are fitted it seems difficult to see. The car seems to handle absolutely fine so it seems unlikely that they are hanging off! I haven't actually got under there myself yet to take a look. I think I will see if I can get a second opinion from a local garage tomorrow before I remove the padlock from my wallet  ;)
amba
They probably are past their sell by date as most parts are on our Omegas now so it would be worthwhile fitting new...but you need to be sure that's what Mot man is complaining about before investing time and ££ changing them...cost isn't great to replace but can be a struggle...we have a "how to guide" but my IT skills don't allow any link ...others may help out though
You'd know if it were the diff mounts... Sling it into a corner and you'feel the car twist and get a fairly hefty thud as the weight transfers back on to the mount.
Makes the car looser than a box of Allbran :o
YZ250
Quote from: Doctor Gollum on 05 January 2020, 18:21:06
my separated one only became apparent when I undid it to change the rear springs. The horseshoe shaped metal outer fell off when I removed the bolts; the rubber and aluminium centre stayed bolted to the diff.
The MOT test requires the car to be jacked(to test the wheel bearings) and now uses shaker plates, so the tester is probably noting movement during one of those operations. The subframe front mounts(the donuts) are most likely, being readily available and a straightforward job, are the place to start
JDX
"The subframe front mounts(the donuts) are most likely, being readily available and a straightforward job"
...they don't look very straightforward from the thread I've read but I'm probably gonna have to try to do them - I think a garage will be too expensive for me.
Thanks for the advice..
Quote from: JDX on 06 January 2020, 10:51:34
I use a cold chisel to make a gap between the bush and the subframe. Then a pair of claw hammers to keep the old part moving. Once it's come out about 5mm, I swap to a pry bar to save some effort. The new bush is drawn into place with its mounting bolt and finished with the jack. About 45 minutes per side, working on axle stands in the street. It's a brute force job, no special tools, techniques or thinking required. Although an impact wrench or long ratchet does save some effort.
JDX
Quote from: Nick W on 06 January 2020, 11:20:49
Are you a young man Nick? :-[
Quote from: JDX on 06 January 2020, 12:20:38
not any more. I make the tools, big hammer and long bar, do the work.
