Author Topic: Astra exhaust gone  (Read 7300 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Astra exhaust gone
« on: 26 February 2020, 12:47:50 »
Astra H 2008 petrol manual
Daughter in London rings up concerned about 'new noise'. Quickfit tells her it is blowing exhaust, quotes £440 to replace. That sounds hot to me, is that reasonable?
Re: Astra exhaust gone
« Reply #1 on: 26 February 2020, 12:54:19 »
£440 might be ok for a full front to back exhaust, but does she really need that?
« Reply #2 on: 26 February 2020, 12:58:59 »
An Omega exhaust costs about £250 fitted. You do the maths...
Joking aside, National Tyre may be a better bet than Kwikfit, and it could be a good life lesson for her to shop around and get it fixed ;)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 26 February 2020, 13:01:26 »
you think that after 12 years, only one section of the exhaust will have rotted?
« Reply #4 on: 26 February 2020, 13:03:34 »
I think that Kwik fit are a bunch of cowboys and would replace it whether it was needed or not.
  • Chatham, Kent
« Reply #5 on: 26 February 2020, 13:15:43 »
most mechanics prefer to fit an entire system in one go, rather than 3 separate visits from an increasingly irrate customer over the next seven months.
« Reply #6 on: 26 February 2020, 13:21:01 »
National tyres quoted me over £200 for a complete exhaust for my daughter's Siecento .... which was about all the car was worth .... even Fiat themselves quoted less.
I bought one from a motorfactors for about £35 .... though it did take 3 attempts to get the right one  ;)
« Reply #7 on: 26 February 2020, 16:15:44 »
Complete cat back setup is circa £100 delivered from the usual suspects (e.g. as per the Omega V6 suppliers)
Not hard to change usually either (front pipe to cat nuts being the worst bit)
terry paget
    • 3 Astras 2 Vectra
« Reply #8 on: 26 February 2020, 17:14:27 »
Thanks to all for advice. Cheapest cat is about £100, cheapest exhaust system again about £100.I will let daughter enquire if quote is complete system or cat back, and price from National Tyes. Have members any experience of detaching cat section from cylinder head? I have had bad experiences detaching exhaust manifolds from 2.0 Omega cylinder heads.
terry paget
    • 3 Astras 2 Vectra
« Reply #9 on: 26 February 2020, 19:08:45 »
I have changed one Astra H exhaust system, cat back. I changed all 3 sections, could not easily separate the sections, so cut it up with an angle grinder. I imagine that is what Quickfit were quoting, the cat should be all right, and looks quite difficult to remove from the head. As said above, trickiest bit was undoing the 3 bolts holding flexi section to catalyst.
I see no harm in letting daughter carry on using the car as it is until Easter, then bringing it home for the fitting of 3 new rear sections.
Has anyone removed the catalyst from an Astra? I see from e-bay pictures that the cat bolts direct to the head. Do the bolts unscrew easily from the head? I ask because I have a donor car in my drive. Is the cat worth saving?
« Reply #10 on: 26 February 2020, 19:13:06 »
I see no harm in letting daughter carry on using the car as it is until Easter, then bringing it home for the fitting of 3 new rear sections.  ....
I thought you were cutting the apron strings Terry .....  :-\ :-\ ::)
« Reply #11 on: 26 February 2020, 19:51:57 »
 :-X
On several points.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #12 on: 26 February 2020, 21:06:22 »
the cat is a manicat ,exhaust outlet manifold and cat combined
your best to keep the original cat ,unless it's damaged ,not working
the flexi joint on the front pipe is a common fail point
about £30 -£35
rear box is stainless IIRC
I've only ever had to replace the front pipe ,which has a post cat lambda
a local garage would probably replace the front pipe (if that is the only issue) for circa £120
example clicky £31.71
terry paget
    • 3 Astras 2 Vectra
« Reply #13 on: 26 February 2020, 22:33:05 »
about £30 -£35
Thanks Dave. That's not how I remember it. I don't recall the post cat lambda in the front pipe. What year did that come in? Son Ben's 2006 Astra H should be here tomorrow, I will have a look. On the one I changed, the pipe went over the rear axle, and as I could not separate the 2 rear sections I had to cut it in two to remove it. Cath's car is a 2008, Jonny's is a 2010, the donor is  2004. I forget which one I changed the exhaust on. I fear it was the 2008 estate wrecked in London, insurer paid me £2000.
terry paget
    • 3 Astras 2 Vectra
« Reply #14 on: 26 February 2020, 23:01:18 »
Checking my records, I did not record which car I fitted the new exhaust to - very careless. I did note that at its MOT in April 2019 Cath's 2008 Astra had a blowing exhaust flexi joint, so no surprise that now it's noisy - I bought it in July 2019. I must check whether the new exhaust is on the donor car.
