Pages: 1 ... 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30   Go Down
Author Topic: Anyone know about Astras?  (Read 115025 times)
Re: Anyone know about Astras?
« Reply #315 on: 05 May 2020, 16:32:43 »
Might be near the filter :-\
I've had a look for the part online - there's seemingly no such thing. I wonder if it's built into the pressure sensor.
I'll see what the kit says shortly - decided to chill out for an hour and have a fry up, first  :y
How many wires to the sensor on the fuel rail?
Three :y
  • Online Online
« Reply #316 on: 05 May 2020, 16:37:29 »
Ecu Pos feed, and temp and pressure returns :-\
« Reply #317 on: 05 May 2020, 16:46:46 »
I've just read the temp sensor is built into the filter housing, under the car. About to have a look, I'm just setting up the desktop PC outside to read the codes, as my laptop has linux on   ::) :y
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #318 on: 05 May 2020, 17:06:12 »
Take the easy route and bring the car inside.
« Reply #319 on: 05 May 2020, 17:36:04 »
Ok, so the only error stored in the ECU, is:
"P06B-41 Fuel Injection Small Quantity Not Learned - Not Programmed".
This makes sense, because the garage said that, after coding the injectors, the small quantity learning was needed, but the process was failing because of an error message about the fuel temperature sensor.
So I have found the fuel temperature sensor. It's here, next to the tank:
You can see it's integrated with the fuel filter housing. There was nothing obviously wrong, the connector was a bit dirty externally, but was seated.
I've taken it off, cleaned it up, and the garage are going to try again tomorrow.
If that doesn't work, I'm not sure what else to try? The car is running worse now , very diesely.
I've tried suggestions about the "tool" such as trying different variants, such as mokka, Zafira, of varying years.
On the Astra J, none of the options even appear for injector programming, etc. With the Astra H, the options are all there, "replace injector" and "small adjustment learning" etc etc, buy they don't work.
It's reading the VIN correctly so it's not a driver issue, etc. Not sure what else I can do, if it doesn't work at the garage. I don't want to take it to a stealer!
« Reply #320 on: 05 May 2020, 17:43:28 »
Replace the temperature sensor?
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #321 on: 05 May 2020, 17:46:25 »
don't let the reader read and identify the vin  :y
 manual input as 2010> astra h > engine> y17dth or similar
« Reply #322 on: 05 May 2020, 18:15:42 »
Fuel temperature sensor is in the fuel filter.
However, the code you see is often seen after messing with the DPF, check the pressure sensor and connections
« Reply #323 on: 05 May 2020, 18:31:38 »
Done that - doesn't work :( Am currently trying a firmware upgrade
« Reply #324 on: 05 May 2020, 18:32:00 »
All are home, present, and correct :y
« Reply #325 on: 05 May 2020, 19:13:57 »
Can you get it to the Nottingham area?  ;D
    • E250 Est / Elroq
« Reply #326 on: 06 May 2020, 07:30:06 »
On the reader that shall not be named?  if so, you'll need to order a new one ;)
« Reply #327 on: 06 May 2020, 10:43:11 »
Yep! Although even then, the listings say they have very limited ability just on Astra J :(
« Reply #328 on: 06 May 2020, 10:48:42 »
Successfully updated from v1,45 to 1.59 without breaking it m
Or are you saying I need to order a new one with v 1.99?
    • E250 Est / Elroq
« Reply #329 on: 06 May 2020, 11:32:30 »
Been a while since I used one, but clicking upgrade used to physically destory the chip, game over time.
Ive no experience on them on later cars
Pages: 1 ... 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30   Go Up
Page created in 0.025 seconds with 20 queries.
