battery powered tig/stick welding set ....
Started by Andy B, 19 April 2020, 21:58:59
 ... who even knew they existed?  ::)
'We' ... ie my maintenance dept at work ... have just bought one. Apparently £3500  ???
YZ250
I've only seen the promotional video for them, Fronius I think it was. Be interesting to see how you get on with it as it's truly stand-alone portable. It will even fit in your car boot for homers.  ;) :y
Quote from: YZ250 on 19 April 2020, 22:39:50
I only saw it for the first time today ... still tucked up in its box/case. It'll be great for welding out & about in the factory as at the moment it takes longer to find a working 415v socket within range of what you want to weld ..... 90 mins set up time & 5 mins welding  ;D ;D ;D
I think we'd need a note signed by the Pope to be allowed to take it off site!  ;D ;D
9 pm on Tues BBC 2 ... Inside the Factory & you'll see what a sh1t hoe a 'Blue Chip Co' is like ..... though I'm sure they found some nice shiny newer bits to film  ;)
dave the builder
I'm sure I remember Lord Opti using one on his wife's Corsa bulkhead /scuttle area a while ago  :-\
ronnyd
Quote from: dave the builder on 20 April 2020, 07:01:27
Thought he only repaired dented laptops.  :o
There used to be a rather crappy solenoid type one that worked off a car battery, completely useless.
Nice bit of kit the Fronius welder, I think they quote it being able to weld 5 or 6 3mm rods on a single charge.  :y
Quote from: Marks DTM Calib on 20 April 2020, 15:08:20
I'll have a look at what make this one is when I'm back in work at the wk end .. nothing like as heavy as you'd expect  ???
I think a mate of mine had a welding set that was supposed to use 2 or 3 car batteries in series years ago. Just looked like a couple of jump leads connected to a stick welder.
I never saw it in action but it seemed like an excellent way to get yourself showered in battery acid to me. ;D
I used this set over the week end. It is Fronius.
All I can say is it's bloody fantastic! Clip the 'earth' to the job, put a rod in the holder, switch it on, a couple of 3 or 4 sec welds.
Job jobbed!  :y :y :y
YZ250
Quote from: Andy B on 05 May 2020, 12:41:45
All I can say is it's bloody fantastic! ........
Make your life at work a lot easier now.  :y
That can only be a good thing if all the sockets are as well wired ass the earlier example...  ::)
Quote from: YZ250 on 05 May 2020, 16:35:07
It certainly will. I spent a couple of hours the other week trying to find either a working 110v or 415v socket near enough to where I wanted to weld. Then less than 5 mins welding.  ;)
Quote from: Doctor Gollum on 05 May 2020, 16:38:47
The spark that wired that up just didn't want to get involved ....  >:(
