Brake Bleeding Question
Started by grifter, 29 April 2020, 11:31:14
ABS pump only runs when wheel lock or Traction Control demands it to fire ;)
deviator
As above really, if you have an eazibleed (have you met my EMO friend? We call her Eazibleed  ;D).
Bleed the air out of the caliper you've replaced. if it's a new caliper, the piston is already retracted. If fitting a second hand one, make your life easier by retracting the piston off of the car, this also gives you chance to 'feel' the seal/piston for any sticking. Once bleed, check fluid level, pump up the pedal and re-check fluid.
I have used an eazibleed before, but I have a pressure bleed that runs on a compressor which I prefer. If you have a compressor, they are really worth having. If you buy a few more lengths of pipe, you can use it for all sorts of jobs. For example I've used a pipe to hoover up the crap in the bottom of the brake reservoir. Or empty the power steering reservoir, then disconnect the return pipe, wedge my suction pipe in the return pipe (may require a few layers of tape to get it snug) and lock it on suck whilst topping up the reservoir. As I use clear pipe, I can tell when the new fluid makes it through the full system.
No I haven't done an engine oil change this way and I doubt I ever will.
Quote from: deviator on 30 April 2020, 12:50:03....
Turning this about, you can use a Pela oil extractor as a vacuum source to do your brakes (I've never done it but know that others have done  ;) )
Yep, doesn't really matter how you bleed the brakes. The objective is to ensure no air remains in the hydraulic circuit.
I bled the Westfield's system from new with an easibleed. Never had to resort to manual bleeding.
Quote from: Kevin Wood on 01 May 2020, 16:06:28
You could almost bleed that from the driver's seat...  :D
New POD
Quote from: Doctor Gollum on 29 April 2020, 11:48:21
Quote from: deviator on 29 April 2020, 11:36:25
I'm not sure if I've understood this correctly.
If you replace a part like a caliper. Bleed as you normally would, either 2 person manual job or a 1 person pressure bleed. Once you are happy the air has gone. Make sure your brake fluid level is on max and pump the pedal to force the pads out to the discs. Re-check level and you're done.
I somehow suspect I'm missing something here?
This.  ;)
Clamp the flexi hose as near the joint disturbed as possible and remove/replace the component. Then bleed as normal...  :y
Just remember that the caliper will take some bleeding due to the volume of air being expelled.
Also, if you didn't clamp the flexi, front or rear dependent on which caliper, then you'll be bleeding the entire system then finding a garage/someone with Tech 2 to bleed the ABS block as well... In this case the car WILL NOT be driveable until this is done.
I'm wondering now.  Some 50k miles ago, due to stupidity of the part of 3 people, at different times, one of my rear brake pistons, came out too far due to using solid rear discs on a 3.2 MV6
Having been delivered home via RAC and obtained the right discs, I just bleed the thing.  I bleed all the calipers, until fresh fluid came out.  Engine off.
It's been fine. ABS definately works and so does traction control.  Was I lucky?
Extremely. It has been known for the piston to come out far enough to allow undetected fluid loss resulting in the loss of brakes.
Quote from: New POD on 01 May 2020, 17:30:22....
due to stupidity of the part of 3 people, at different times, one of my rear brake pistons, came out too far due to using solid rear discs on a 3.2 MV6 ...
Why wouldn't they query the different discs when they took them out of the box? And why would they fit them?
You were very lucky!
We saw that years ago with Mike Dundee's car at Newark .... some one had done the very same thing & fitted sold discs instead of vented ...... there was brake fluid every where
New POD
Quote from: Andy B on 01 May 2020, 18:19:57
Okay I bought the car with solid discs.  I got a good deal on a set of 4 discs, and when the website I ordered them off had 2 options, I went outside and looked through the wheel and saw solid discs, so that's what I ordered.  However, I ran out of time, and paid someone to fit them.
He was supposed to be a mechanic but hey.
I was lucky because they were getting spongy, and I stopped at the petrol station just at the bottom of the cat and fiddle road in Buxton. And there was smoking fluid all over the back wheel.
When I fixed it the following week, I couldn't believe that I would have missed it, if I'd have been fitting new pads and or discs. Not if I were an experienced mechanic  The fact that the caliper is not central over the disc seems to be a big obvious red flag.
biggriffin
Quote from: New POD on 01 May 2020, 18:54:33
Photos of calipers,  and Measurements of them might help people's say weather they are Vented or non Calipers.
Hoof'land storeman.
Quote from: New POD on 01 May 2020, 18:54:33....
I honestly wasn't trying to lay the blame on you  :y :y
As you suggest, an experienced mech should've questioned it, especially as you say, it's obvious when the disc isn't central in the caliper.
New POD
Quote from: biggriffin on 01 May 2020, 19:09:43
To be honest it was obvious. On the one side a new pad just fitted nicely with the piston fully pushed back and on the other side the piston was half out. Unfortunately when buying them, I assumed the previous servicing was competent. And we know what comes of assuming too much.
And why most Omega require a grand spent on them on purchase :-X
New POD
Quote from: Doctor Gollum on 01 May 2020, 21:11:08
to be fair, if I sold it now, you'd probably want to spend a bit on it. In the next 3 months it needs a new full exhaust, the gearbox oil changing and a service. Then in about a year it will want wishbones and a cam belt.
This is why I need to get back to work.
