Brake Bleeding Question
Started by grifter, 29 April 2020, 11:31:14
grifter
If your system is otherwise fine and you want to change the fluid, a one man bleeder seems to do a fine job, however if you replace a part like a caliper or rear piston, you then need to actually bleed the brakes i.e. until the piston comes back into contact with the disc or drum. Obviously the new part will be set back into it's recess, or placed at a standard position, and it needs to be forced out till it meets the contact surface of the disc/drum etc.
Is there a tool that lets you actually do this job one-man as at the moment you can only bleed the fluid through the new part, using air-pressure on a one-man bleed kit, but not actually push the piston/cylinder back to the contact surface of the pad/disc.
Diamond Black Geezer
If the essential result is that you don't want the piston to move toward the disc, would not a handy block of wood wedge this fine? Leaving you to bleed the brakes as per?  ???
deviator
I'm not sure if I've understood this correctly.
If you replace a part like a caliper. Bleed as you normally would, either 2 person manual job or a 1 person pressure bleed. Once you are happy the air has gone. Make sure your brake fluid level is on max and pump the pedal to force the pads out to the discs. Re-check level and you're done.
I somehow suspect I'm missing something here?
Quote from: deviator on 29 April 2020, 11:36:25
This.  ;)
Clamp the flexi hose as near the joint disturbed as possible and remove/replace the component. Then bleed as normal...  :y
Just remember that the caliper will take some bleeding due to the volume of air being expelled.
Also, if you didn't clamp the flexi, front or rear dependent on which caliper, then you'll be bleeding the entire system then finding a garage/someone with Tech 2 to bleed the ABS block as well... In this case the car WILL NOT be driveable until this is done.
grifter
If you've pushed the pistons back in,they don't move back in with those one man bleeders, you have to have an assistant pressure the system from the pedal to force them out. If you're on your own you can't do that. I have however just read in car mechanics mag you can get a one way valve bleeder that lets you bleed from the pedal.
https://www.lasertools.co.uk/product/7700
grifter
Quote from: Doctor Gollum on 29 April 2020, 11:48:21
This.  ;)
Why would you need tech2 to bleed the system?
Quote from: grifter on 29 April 2020, 12:11:11
This.  ;)
To cycle the ABS pump to clear air that will be in there :y
Quote from: grifter on 29 April 2020, 12:10:04
You'd bleed the system where ever the pistons are ....
Quote from: Andy B on 29 April 2020, 12:19:56
This.  ;)
Possibly, every time I have been I this scenario its not been required  :y
Quote from: Marks DTM Calib on 29 April 2020, 12:25:44....
I've never emptied a system to even think about cycling the pump  :y
Quote from: Andy B on 29 April 2020, 12:42:25
I only mention it in case the system has been left open ;)
Quote from: Doctor Gollum on 29 April 2020, 12:42:59
:y :y :y
YZ250
#12
I feel that I'm missing something as I agree entirely with the above and can't see what the issue is.  :-\
As said above, if you've replaced a Caliper or piston, bleed the system as normal (2 man or 1 man Eezibleed Kit) and when you have done that you are in exactly the same position as if you had retracted the pistons to change the disc pads, ie. the Pistons are out, as in not touching the brake pad against the disc, You then check the fluid, press the brake pedal, check the fluid again, and press the brake pedal until normal service is resumed.
Certainly no special tools needed.  :y
So, new Caliper on with disc pads fitted (with the pistons retracted as they would be if you'd fitted new pads), bleed brakes to fill Caliper with fluid (using Eezibleed if working solo), check fluid, pump pedal to push the piston out until solid, check fluid again.  :y
Apologies if I'm missing something.  :-\
Viral_Jim
Colour me also confused. I thought that Laser tool was just a budget alternative to an ezibleed...
dave the builder
Quote from: Viral_Jim on 29 April 2020, 18:15:15
or better still go to a pet shop and buy 2 x one way fish tank airline/airstone valves for 99p and a metre of airline plus a jam jar. :y
or, even cheaper  :)  just use a tube long enough to reach a jar with a little old brake fluid in (with the end of the tube submerged in fluid)
as for running the ABS pump, surely it runs when the engine runs, so all you need is the key for the car  ;D
omega A you can bypass the heavy duty relay even without the engine running to run ABS pump  :)
