Wheel Alignment....
Started by MikeDundee, 03 May 2020, 11:58:43
MikeDundee
Below is the results from last year, never done the rear for obvious reasons, this is the same place that recently powder coated the rims, and I plan taking back there once the rear struts are done, I think they got the fronts well out from what they should be?.......
1°10 for the front camber.
Half that for the Toe, so 0°05.
Rear will be where ever it fall re camber and Toe, but the Thrust angle must be ZERO.
MikeDundee
Quote from: Doctor Gollum on 03 May 2020, 13:47:41
Well they never even got that right, advises on right hand column what should be one is at 1.28 the other at 1.18, I will need to duly make sure they get it right when I go and sort the alignment out, insist and take no prisoners as they say - LOL!!!!
If they say that they can't and therefore won't, then they're in the wrong job.
1°15 or less is acceptable, as there are variations according to which struts are fitted etc, but you need it as close to 1°10 as possible. You'll notice the difference immediately between an OK set up and spot on  8)
biggriffin
Before I took mine, I fitted new ball joints, removed the strut bolts, cleaned all the slots,and lashed copperslip everywhere, removed rear tie rods, greased and re-assmbled, so they had no excuses to say it wouldn't move,, also check tyre pressure before going to alignment place..
Hoof'land storeman.
