2.2 dti water pump seized
Started by mmcg, 08 June 2020, 23:44:40
mmcg
HI after 4 or 5 years parked and several failed starting attempts.I finally changed leak off pipes and jump started from 98 landcruiser it started easy. A lot of grey smoke and very loud whine  any way to free pump or is it easy to remove :-\
Opelduude
A seized water pump is nothing to repair.
Change it.
It's fairly easy.
Loosen the screws on the water pump pulley before you take of the belt.
Take of the pulley and you have access to the screws that holds the pump.
Clean the part where the o-ring on the pump meets the engine block before putting in a new one.
mmcg
