Airconpipe
Started by Raeturbo, 23 June 2020, 21:35:22
Raeturbo
Low pressure aircon pipe wanted👍 :y
Laying a rubber road.
tango
If you tell my what pipe it is
I can check if I still have one the car
Raeturbo
It's the top one with the silver bulge on it.  :y
tango
Rubber pipe runs over the pass side coil ???
Ok I'll check for you
Raeturbo
biggriffin
Hoof'land storeman.
Unfortunately the vast majority of these now leak where the plastic spacer clips on to keep the brake vacuum hose spaced. Problem is you don't realise until you gas the system and put it under pressure.
Tried to find a method of repairing them but all attempts have been unsuccessful so far :(
Quote from: VXL V6 on 24 June 2020, 14:24:59
Decent speed tape, ie 3M stickyback aluminium tape, and jubilee clips :-X
Quote from: Doctor Gollum on 24 June 2020, 14:34:26
Unfortunately you can't get quite close enough to where it pinholes.... at least not on the ones i've looked at.  :'(
Quote from: VXL V6 on 24 June 2020, 16:52:11
If it's a pinhole, stick a pin in it.  ;D
Raeturbo
Trust you to stock your oar in ;D
Raeturbo
Raeturbo
Quote from: tango on 24 June 2020, 11:23:29
              yes that's the one👍
