CID wiring and screen wanted
Started by neil74, 21 July 2020, 10:00:12
neil74
Hello all, Does anyone have the colour screen and the necessary pieces of wiring etc so I can install an NCDC 2013 into my dashboard please?. I have asked elsewhere but unsurprisingly they've suddenly gone deaf and dumb.
Cheers
Neil.
Migv6 le Frog Fan
You do know it isnt just plug & play ? Either the screen and headunit need to stay together, or the headunit and new screen both need to be depaired / put into delivery mode, and then paired to one another vie Tech 2.
neil74
Yes I realise all that. but it would be nice to get the parts together so I can at least try and sort something out as i'm fed up with not having anything in the dash that actually makes a noise..
GastronomicKleptomaniac
Quote from: neil74 on 21 July 2020, 15:06:43
But without the paired unit, you'll still have something in the dash not making noise... it'll just have some more wires and a screen stuck to it.
Do it properly once and it's a lot less stress!
What headhunt is currently fitted.
joshwyatt
Neil, I've just read your PM. I unfortunately don't have the wiring you'll need. Of the units you had, one unit and screen had the registration of the original vehicle, not that this in itself will help, it was purely to show which unit was paired. I suspect some of the other units are paired, but unfortunately that's unknown to me.
I believe the GID/CID wiring is present in some cars, it has been in cars I've had previously.
dave the builder
Indeed  :)
I took the OEM wax disk radio gram player out of mine and fitted andriod with bucket avoidance rear view camera etc
cheap as chips and sounds pretty good
Alternate head units will require Neil to rip all the Bose out, loop the cabling at the kick panel and replace all the speakers.....
Quote from: VXL V6 on 21 July 2020, 23:34:08
Not necessarily...
Wiring an aux in to the cdc audio allows a separate headunit/source to successfully drive the Bose gubbins ;)
I found it easier to run new wires from the headunit, and splice them into the existing speaker wiring just before they go into each door. Left all the Bose stuff in place, with no modifications as it was no longer needed.
I fitted new speakers for two reasons: Bose don't work with 'normal' radios, and half of them were knackered.
Used a 2DIN Android head unit, cheap and effective way of getting built in sat-nav, handsfree, OBD diagnostics(not on a 3.0l Omega), dash cam, reverse cam and no longer using outdated cassettes/CDs
Quote from: Doctor Gollum on 22 July 2020, 00:23:22
Not necessarily...
True, but as I understand it Neil doesn't have a working or even half working unit to base that solution on at the moment.  :-\
Quote from: Nick W on 22 July 2020, 09:21:27
I found it easier to run new wires from the headunit, and splice them into the existing speaker wiring just before they go into each door. Left all the Bose stuff in place, with no modifications as it was no longer needed.cassettes/CDs
Facelift Bose equipped cars should have the plug in the kickpanel, if so it's a simple case of fitting the 'looped plug' in to effectively remove the Bose amp out of the equation. Granted having to change the speakers means removing door cards anyway.  :(
Quote from: VXL V6 on 22 July 2020, 09:39:07
Not necessarily...
Thinking this through, what if that problem is the Bose Amp rather than the headunit? :-\
Quote from: Doctor Gollum on 22 July 2020, 09:50:54
Not necessarily...
Could be. <ore detail needed really
