Driving Abroad
Started by Tricky Dicky, 21 July 2020, 13:33:50
Tricky Dicky
Hi all.... after a bit of help & advice - I always thought there was no way to switch xenon headlights over to driving on the right. According to the handbook you can switch over standard headlights but there is no reference to xenons. It's never bothered me in the past and I've never been flashed at (oo-er) when driving at night on the continent but, after 7 years of ownership, I've just discovered there's a tab on the headlight with arrows and L & R...   Are xenons switchable? The main reason for asking now is that I'm moving to Germany in a couple of weeks and taking Oma with me. I had planned on getting new German lamps or lenses to get it through the TUV and then registered there. I've got a pic of the tab on the top of the headlight but I don't seem to be able to attach it (?)    Thanks for any advice, Rich
Xenons are switchable but you'll need to remove* the unit to do it as the bulb cap is screwed on :y
*Whilst you can technically do it in situ, it's easier out of the car and with it unplugged, you're less likely to elwctrecute yourself  ;)
omegod
Quote from: Doctor Gollum on 21 July 2020, 13:58:36
I recall hearing that those ballasts pack quite a punch
Tricky Dicky
Okay - thanks for that. I don't suppose there's a guide for it?  Any ideas if this will be good enough for ze German TUV ?   I'm just thinking about replacing the lenses anyway as they are getting cloudy now. There also seems to be a wide variation in prices for new lamps on Ebay.de...
The lever doesn't convert a RHD lamp into a LHD one.  It just blocks some of the light output away from the now oncoming traffic, like the traditional stick-on patches did but in a more convenient way. This is obvious if you remember to switch them halfway through a 2 week holiday in the middle of nowhere in February - suddenly it's like driving behind failing sealed beams again
As has been stated, it does not convert LHD lights to RHD or RHD to LHD.  The levers convert the beam to a flat pattern which would certainly fail a UK MOT,
The levers are there on all Xenon cars, and takes a few seconds to do - rubber cap off, flick the lever, rubber cap on. Done.
Quote from: TheBoy on 21 July 2020, 21:08:51
Not in my experience .... I set mine to "flat" for a french holiday and as it was raining at the ferry terminal (where I usually changed them) left them there on the way home, and then forgot about them !!!  Nothing said at all at the MOT, only noticed when winter came and it got dark much earlier so the lights were actually used in anger !!
Quote from: Entwood on 21 July 2020, 21:35:31
What Entwood said as I've done the same .... the MOT test is just testing to ensure you're not blinding people.
I left mine set to flat, as the NS one was a pain to get to without loosening the battery.  And it passed a couple of times. Then it failed with an incorrect beam pattern.
Technically it is a fail, but most likely depends how grumpy my grumpy MOT tester is on a given day ;D
Broomies Mate
Quote from: TheBoy on 22 July 2020, 17:53:54
Tell Grumpy MOT man to Foxtrot Oscar!
4.1.2. Headlamp alignment
You must inspect all dipped beam headlamps fitted.
The type of headlamp will determine whether the aim must be checked on dipped or main beam (see Diagrams 1, 2 and 3).
A flat top or other alternative headlamp dipped beam pattern is acceptable as long as all of the beam upper edge, including any 'peak' is contained within the appropriate tolerance band.
It's acceptable for masks or converter kits to be fitted to right hand dip headlamps to temporarily alter the lamp for use in the UK by removing the beam 'kick-up' to the right.
If driver's beam aim controls are fitted, you should test the beam aim without altering the control setting. If this would result in failure for beam aim being too low, you should re-check the beam aim with the control set at its 'highest' position.
On vehicles with hydro-pneumatic suspension systems, it's necessary to have the engine running when checking headlamp aim.
Tricky Dicky
Thanks all for the advice... I think I'll get some new lamp units when I get over there.  :y
Given that it's a long term move, that's probably the best approach  :y
