Author Topic: Omega B mv6 ECC keeps restarting.  (Read 3128 times)
Rocketry23
    • Omega B MV6
« on: 23 July 2020, 19:16:35 »
Hello!
I have a weird problem with my 1996 Omega x30xe. The ECC panel keeps restarting many times in a row, like it drops voltage for a millisecundum.
This happens only when engine is running.
I tried to give the panel 12v directly from battery to the connector on pin 1, 4, 12 and direct negative on pin 2. The problem still exist. Only when engine running...
What might be the problem?
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Omega B mv6 ECC keeps restarting.
« Reply #1 on: 23 July 2020, 19:41:27 »
I can only think of one connection between the engine running and not, and that would be a signal to say the AirCon pump is running/not running.
Switch the panel to ECO mode (aircon off) and see if the problem persists.
Rocketry23
    • Omega B MV6
« Reply #2 on: 24 July 2020, 15:45:27 »
I will check this but atm the system is empty, i fitted new evaporator and compressor, so the compressor not running anyway.
The problem existed before the component change.
