Wanted - new genuine / original GM LH wishbone 90576788
Started by johnnydog, 30 July 2020, 15:53:52
johnnydog
As the title - anyone got a new (or old stock) unused genuine GM LH front wishbone (90576788) that they would be willing to sell or trade?
Checking my spare parts, I have two new genuine GM RH wishbones (90576789) packaged with GM labels, but ideally would like to make a pair, by buying a new LH (even two!) or swapping a new RH for a new LH.
I would like genuine GM to make a matched pair/s.
TIA.
The ball joint is the only thing that makes it left or right.
biggriffin
Just rebush, new ball joints, and poly-bush, the ones you have on the car.
Hoof'land storeman.
johnnydog
Whilst the point DG makes may be correct, the corrosion on the existing ones doesn't make BG's suggestion viable, so my original ask still stands... :y
Quote from: johnnydog on 31 July 2020, 13:10:43
New or corroded, people have been rebushing Omega wishbones for decades ???
If the ball joint has a knuckle on the rear face, then these are sided whilst those with no knuckles are reversible. Either way drill the rivets, and swap out/rotate the ball joint.
Both Genuine and aftermarket ball joints include the bolts for refitting them.
Also worth noting that the rrp for genuine wishbones is almost £300 :-X
New POD
Quote from: biggriffin on 30 July 2020, 16:20:04
Where does one find the ball joints ? Or rather, which of these would you recommend?
https://www.ebay.co.uk/b/Car-Ball-Joints-for-Opel-Omega-B/33580/bn_7000401675
I've used Delphi to good effect... Mostly because my local factors stocks them for less than a tenner. Genuine aren't particularly expensive as I recall ;)
johnnydog
Only taken 2 1/2 years - but I managed to find a genuine GM one in Germany at sensible money last week. So that's me sorted with a matched pair :y
You wouldn't have thought they were that hard to find without paying extortionate US prices...... ::)
Good job you didn't need them 2.5 years ago then ;D
Migv6 le Frog Fan
The original balljoints are more often than not in perfectly good condition and dont need to be replaced with something inferior.
I found this out after I had replaced mine as a matter of course while rebushing my wishbones.  ::)
Genuine GM bushes for the rear of the wishbone and polybushes for the front. Tightens things up nicely.  :y
