cant get started
Started by john1959, 01 August 2020, 17:50:23
john1959
car been running great,went to start it just no power faint dash lights central locking not functioning had new starter motor 4 months  ago new battery 6 months ago green showing and new alternator 9 months ago and aux belt had gearbox recd all great but engine not turning or any sigh of life.what could it be???
Enceladus
#1
The magic eye only measures one cell. So the battery can be shot and still show green. Measure the battery resting voltage with a voltmeter. Should be 12.6/12.7v fully charged and rested.
Troubleshooting guide can be found here.
john1959
thanx do think it maybe the key battery?
Quote from: Enceladus on 01 August 2020, 18:21:09
Best thing you can do with a magic eye on a battery is put a piece of tape over it. Then you won't be tempted into thinking it's doing anything useful.
You need to use a multimeter to do some practical diagnosis.
Enceladus
Quote from: john1959 on 01 August 2020, 18:29:02
Nope. That would stop your central locking from working. But wouldn't affect the dash lights or immobiliser.
Has it been raining heavily, or car parked a long time and not used, or interior reading lights left on maybe? First thing to do is to check the resting voltage at the battery terminals. If it's not fully charged then charge it up, preferably off the car.
There's an exceptionally useful guide :y
robson
Have you got the radio code you will need it if you disconnect the battery.
Quote from: robson on 01 August 2020, 20:42:58
Why?
john1959
i called greenflag out guy reprogrammed key and immoblizer battery  flat  he said i pumped tyres up yest with 12volt pump first time i did it without running engine at same time so must have drained battery and caused all this madness.running fine now he said if battery goes flat again get it back to halfords for replacement 5 year guarantee only had it fitted in jan
zirk
Quote from: john1959 on 01 August 2020, 23:30:53
leaving a Battery permanently connected to an Omega whilst the Car is just sat up doing nothing will finish off the Battery in a very short time, it may recharge ok but it will never be the same again.
If your going to leave it parked up for long durations just diss the Neg lead and place some plastic or cupboard in the way of the terminal. If the Power Sounder starts miss behaving then remove the PS completely.
BazaJT
Would that be a genuine GM cupboard Zirk or will any cupboard do? :D :D :D ;D ;D
A pattern one might not fit too well, space is a little tight there :D
New POD
Quote from: zirk on 02 August 2020, 14:23:06
I'll be attaching jump.leads to my omega tomorrow. It's not moved since lockdown began
Wish me luck. I suspect I might need a new battery.
I'm sure it will start, I'll drive it to the house, and put the charger on the battery, whilst I replace spark plugs and air filter, and see it it starts again the next day without jump leads. I do hope so. Otherwise a new battery will be required I reckon.
If it does, I'll be finding a local garage to replace the exhaust.
New POD
Quote from: New POD on 02 August 2020, 21:45:23
Help.  I can't get the thing started. 3.2 MV6
Put jump leads on from wife's car, ( with it running)
Engine turns over, but no fire.
Replaced spark plugs ( was planning to do that ) still no start.
I've given up for the day, in disgust.
Any ideas ? Oh and to add insult to injury, my cheap blue tooth code reader doesn't seem to be working properly.
zirk
First off read any fault codes using the Peddle Trick
