Electrolysis Tank - Rust Removal
Started by grifter, 06 August 2020, 22:59:15
grifter
Has anyone else set one of these up to put rusty parts in?
I set one up a couple of months ago and it's the best thing I've ever found for removing rust, completely.
I'm now using my blue wheelie bin to put larger parts in  :). Easy to set up, just a sacrifical anode plate and a power supply wired to the anode and the part in the water. Add some baking soda and it starts bubbling the rust off.
Unfortunatley I don't yet have a tank big enough to put whole omega in!!
Quote from: grifter on 06 August 2020, 22:59:15
Maybe Lord Opti will let you use his swimming pool!  :y       ;D
biggriffin
Why do I sense, doing something like this being done by a Brackley member, might not go well,, isn't the gas produced by electrolysis Explosive :D
Hoof'land storeman.
I'm now using my blue wheelie bin to put larger parts in  :) . Easy to set up, just a sacrifical anode plate and a power supply wired to the anode and the part in the water. Add some baking soda and it starts bubbling the rust off.
Next step is a basic nickel plating kit to refinish your newly cleaned parts.
Having  a big enough tank to put the whole Omega in would provide a new way of getting rid of a rusty hulk: you could pour it down the drain :)
grifter
Quote from: biggriffin on 07 August 2020, 10:16:13
Only in an enclosed area, it's basically the same as a battery venting hydrogen.
grifter
Quote from: Sir Tigger QC on 06 August 2020, 23:11:19
Scary that I actually thought of that as an idea!
biggriffin
Quote from: grifter on 07 August 2020, 15:47:36
   I thought so.
Hoof'land storeman.
cam.in.head
never tried electrolosys yet but have had good results over the years with deox-c
