Spot difference,,, Pas pumps
Started by biggriffin, 09 August 2020, 20:18:45
biggriffin
 Okay, I supplied a pump to a member which I had in stock, for a 3.2. just had picture, pump supplied is different to the one said member has, I think his pump is 3.0L pump, I will be giving the member a full refund... Picture below, supplied pump is the clean one. Any one identify ???
Hoof'land storeman.
biggriffin
Hoof'land storeman.
Did it not fit?
If the mountings and fittings are the same, then no reason for not to work :-\
Quote from: Doctor Gollum on 09 August 2020, 22:36:06
Did it not fit?
But it would still be a modification!!!
biggriffin
 From what I can remember, the fitting which goes into the pump is different, .
But I cannot understand why a 3.2 would have a what looks like a 3.0L pump, unless previous owner did modify the fittings..
Hoof'land storeman.
Quote from: biggriffin on 10 August 2020, 07:24:41
I recall the pump change did not align to the engine change year, so there was probably a short period where the 3.2 had the old pump, is it an early 2002 car?
biggriffin
Quote from: Marks DTM Calib on 10 August 2020, 09:30:24
I don't know what year the car is,
As I said it does look like it has the earlier pump fitted, looking at the picture, just trying to make it easier for the member to get the correct pump,
Hoof'land storeman.
Its definitely the earlier pump they have, the round rear disc with circlip is the give away  :y
biggriffin
Quote from: Marks DTM Calib on 10 August 2020, 10:56:25
That's great Thanks,, :yso he needs a 2.5/3.0L pump.  I will message him the news..
Hoof'land storeman.
