Wanted: Right rear window motor
Started by TheBoy, 12 August 2020, 13:27:54
I guess its the motor, seeing as the window wont move. So I need another, priced with posting to Brakkers.
Does it click when the switch is pressed?
If not, presumably you've checked the wiring...  ::)
Quote from: Doctor Gollum on 12 August 2020, 13:33:53
No noise that I've heard, so I was going to go into the job with the most likely component to hand - seen far more failed motors than rear loom faults, though aware they do sometimes fail right by the connector in the B post.
Quote from: TheBoy on 12 August 2020, 13:53:05
And the driver's door loom/switch. Rear windows are both powered from the driver's door switch.  ;)
A failed motor should still click with an associated dimming of the interior lights (ign on/eng off).
Motor body can also be removed in situ for testing purposes.
Quote from: Doctor Gollum on 12 August 2020, 13:59:06
A jammed motor or mech will click. A failed motor wont.
Should still show power past the switch ;)
Quote from: Doctor Gollum on 12 August 2020, 14:41:02
Yeah, but if I'm having the dooryard off, I want a window mech to fit. As we all know what the most likely fault is.
I would almost wager a curry on that...
annihilator
