SIM card
Started by LFF64, 20 August 2020, 18:24:50
LFF64
Hello people
I havent been on here for ages I havent even had a Vauxhall for the last vouple of years now currently running a Mercedes ML320 2007 as I am towing a caravan again
I need some advice and you guys have always been the best place to ask  :y
What I have is a Truma inet system in the caravan which allows control of the heating among other things.
It requires a mini sim to use it and works by sending texts to a phone so I need it to do that preferably pay you go and as it is going to be very low use not cost a lot per month
Any suggestions  please  :)
Any PAYG sim will suffice, and most can be bought readily for 99p.
If travelling abroad, then 3 would be my first suggestion as their roaming are rates are very good.  :y
dave the builder
O2 classic is a very cheap basic PAYG tariff with good coverage (important if using in a car tracker or similar)
https://www.ebay.co.uk/itm/O2-Pay-As-You-Go-The-Classic-PAYG-Package-Standard-Micro-Nano-SIM-card-02/113262991137?hash=item1a5f001721:g:5PoAAOSwzUJbpVSh
3 pence a minute calls, 2 pence each texts & 1 pence per MB data  :y
top up a tenner every 6 months
LFF64
Thanks guys I have been pointed in the direction of an M2M type sim which seems to be made for the application
Does anyone know much or anything about these  :)
Long time no see. :y
You could do with finding out what technologies (2G / 3G / 4G) the cellular module supports and on what bands because if it's more than a couple of years old it won't support all of them.
That will determine your choice of network operator. e.g. if it  only does 2G, then 3 will be no use whatsoever.
Broomies Mate
Quote from: Kevin Wood on 20 August 2020, 21:15:10
3 network is the shittest of the shittest you can get.  Avoid at all costs!
YZ250
Truma iNET is 2G so you are looking at either M2M (roaming) or Giff Gaff/ O2. M2M appear to do reasonably priced payg for this type of set-up. It's SMS Sim you are after so you don't need a massive data package.
Martin, send Mrs LFF64 on ahead to turn the heating up so that the van is toasty warm by the time you get back to it, and then you won't need a Sim.  ;) :y
we just leave the heating on but set to a slightly lower temp.  :y
YZ250
Quote from: Andy B on 20 August 2020, 23:47:53
That's what we did but I believe that with an iNET Box, it also allows those that store their vans away from home (in storage) to keep an eye on battery status etc.  You send an SMS to the van iNET Sim and it responds accordingly. Not sure what else it can do though.  :-\  It works on Bluetooth and SMS I believe. The Bluetooth bit puzzles me, because if you have to be in Bluetooth range, why not just pop in the van to do whatever you want it to do. Maybe I'm missing something there though.  :-\
My van was either on site with me in it, or sat in my drive plugged in anyway so battery not an issue. On site, I'd paid for my electric so it's fair to say the van was never cold.  :y
LFF64
Hello  :)
Your joking she won't touch it
And you are correct it is Bluetooth and SMS  it can control the heating but it is also able to monitor the battery and gas cylinder levels , just a bit of a toy really .
I am looking at a M2M type card as these can apparently switch networks depending on where it is parked
Quote from: YZ250 on 21 August 2020, 06:17:21
Sounds like the Mercedes Me App .... it'll tell you what's in the fuel tank, tyre pressures (if you have a direct system), where you've parked it ......  ???
How did we manage when we had to just remember from the last time we used the car?  ;D ;D
It will have to monitor battery voltage as its thats module which will be the major source of battery drain
YZ250
Quote from: LFF64 on 21 August 2020, 09:37:03
If it has a toy, it must work, that's the law.   ;D :y  Hope you get it sorted.  :y
Quote from: Marks DTM Calib on 21 August 2020, 10:33:58
There's an irony in there somewhere.   ;D :y
LFF64
The battery will be good it is connected to a roof mounted 100W  solar panel  :y
henryd
Quote from: Broomies Mate on 20 August 2020, 22:19:09
Really ?, I have been on it years and found it better that Voodoo phone and EE who I was previously with. perhaps its just down here in Cornwall ???
other rides
