complete front v6 o/s strut
Started by cam.in.head, 30 August 2020, 08:27:41
cam.in.head
nothing received ?
have you got a strut ?
thanks
Quote from: cam.in.head on 03 September 2020, 19:41:05
nothing received ?
thanks
I think he meant me......
cam.in.head
sorry nick. just read the pm bit !
cam.in.head
theres a 2.5 diesel strut on ebay and the info says its for petrol 2.5 as well so i assume its the same spec .can anyone confirm this as its the only one i can find so far. messaged omegas52 and some others on ebay but no replyies yet .thanks
Quote from: cam.in.head on 05 September 2020, 07:45:10
I would expect a stiffer spring to hold up the heavier diesel engine
You can assume what you like, but fitting it to a petrol V6 would be dangerously stupid as it would completely unbalance the front end.
Basically, for any given application, front springs are, in ascending weights, as follows : all 2.0/2.2 16v petrol springs are the same; all V6 and 2.2 diesels are the same; all 2.5 diesels are the same.
Rear springs are, again for any given application as follows, saloon all the same; estate all the same.
Springs will vary in number of coils/ride height/ suspension type, but will nevertheless carry the same weight for any given application.
Spring weight should be half the axle load, from the chassis plate, and the same side to side. From memory, four cylinder petrols are 990kg front, v6 and 2.2 are 1080kg front and 2.5 diesels are 1130kg.
johnnydog
Quote from: Doctor Gollum on 05 September 2020, 10:15:53
Actually, according to the EPC, the same front springs are fitted to a 2.5TD as to the 2.5 petrol model.
It also lists the same spring for 2.5 /3.0 petrol models (although different part nos from the above :o).
So make from that what you will .... ::)
The front springs for the different models is an absolute minefield, but personally, I think you would be ok for the short term in fitting (if you can find a matched pair of them) a set of struts from a 2.5 TD to a 2.5 2.6 or 3.0 petrol until you can rebuild your existing ones.
But then there is no guarantee that a previous owner hasnt mixed and matched in the past, although the likelihood of having replaced front springs is a lot less than the rear springs.
cam.in.head
Hi . Was actually goin to pm you yourself in case you hadn't seen this wanted ad. I beleive you sometimes break omegas or have I read wrong somewhere.
The strut is needed because my brothers had 1 faulty unit( the spring seat was rubbing on the tyre )so I put one of mine on his to get him going short term. Now I just need one to put back on mine or back on his ,either way.
Yes I saw the unit being mentioned as suitable as for a diesel 2.5 or petrol 2.5 too but was then told otherwise so have found out now that a 2.2 dying one is the same also.
cam.in.head
That should have read.   Diesel. !
Spring seat rubbing on the tyre isn't a strut problem. That's either wrong size tyres, wrong wheel offset, incorrect geometry settings, or all the above ;)
Quote from: Doctor Gollum on 06 September 2020, 19:15:53
A bent strut might do it, but there would be (lots of) other damage. Loose strut to hub-carrier bolts are by far the most likely cause
johnnydog
Quote from: cam.in.head on 06 September 2020, 17:41:40
Just to throw a further spanner into the proverbial works, according to EPC, the 2.2 D front springs are a different part no from the 2.5 TD and 2.5 Petrol, but the same part no as the 2.5 and 3.0 Petrol. Work that one out.....!!
Must be chassis no changes, but I can only see the difference being negliable, but still should be a matched pair.
I bet you wish you had kept your own strut now...... ;D
cam.in.head
il find one and if necc just put a pair of new ones on.mines on sorn for now anyway so no big panic.
definately the strut seat faulty.it has become weak with rust and gone level to the strut rather than the upward tilt it should have.other one and mine all fine with approx 1" of clearance ..
standard wheel and tyre,camber 1.1 deg.
would have put 2 new on his but needs car everyday to get to work hence the panic swap job !
theres a 2.2 diesel strut and a 2.5 diesel strut on ebay so unless anyone has one on here il prob go for that for now.
cam.in.head
please close thread.
strut found now on ebay.thanks
