complete front v6 o/s strut
Started by cam.in.head, 30 August 2020, 08:27:41
cam.in.head
hi. has anyone near to halifax got a front strut complete with spring mount etc ready to fit for a v6 please. idealy today or tommorow !
long shot i know but needed to do pre booked mot then new ones can be fitted at a later date.
many thanks.
cam.in.head
ok mot sorted now but still looking for a complete v6 strut.anywhere now not needed to be local .if you have one ( std spec) price inc postage please. nothing obvious on ebay at the moment loads of 2.2 ones .but no v6
many thanks
The only difference is the spring... Which you are presumably re using or replacing  ???
cam.in.head
thanks dg thats what i thought. just looking for a unit complete ready to fit but for a v6.
what about THESE?
£25 for a pair delivered, is surely the way to go? Especially as you'll need to have the car aligned no matter what sort of shock you buy.
dave the builder
Quote from: Nick W on 01 September 2020, 21:00:41
what about THESE?
those are Omega A / carlton ones ? looking at the engine lists  :-\
hmmm, good point. I've never thought of Carltons as Omegas.
I was surprised by that listing, as I was expecting new Omega struts at about £40 each. Which I would still buy instead of a used-up one.
The only use of a complete second hand strut is that it allows you to build up a new strut/spring/topmount ahead of doing the actual job...
dave the builder
Quote from: Nick W on 01 September 2020, 21:43:33
Indeed , used shocks with 100K / 15 years of being worn out probably not a good move
I'd replace both fronts with new at the very least
then I'd remember the backs are just a nut and bolt to swap and be ordering those too  ;D
Quote from: Doctor Gollum on 01 September 2020, 21:49:19
which takes half an hour if your slow , so may as well fit new
[/size] New spring, bearing, top mount and bump stop/dust cover, as on all of those parts were knackered on every one I've taken apart. It costs about £100 in parts per side, but means the front end is good for at least another 100,000 miles)more than the life of most remaining cars) without issues. All I want from a strut are the rubber isolators, spring cup and spacers/washers. I still have a spare set of those, so would build a complete strut in a spare 5 minutes. Like I did here:[size=78%]
into this
that was several days before we started on the car.
cam.in.head
new ones will be fitted in due course just thought someone would have one from a breaker. have messaged a few sellers on ebay but not heard back yet.
thanks for replies
Quote from: Nick W on 01 September 2020, 22:15:55
into this
Exactly  :y
amba
And the transformation after having them all fitted new by NickW was a totally different car and dont regret the cost a few years ago now....just need a man with a welder now !!! :)
Quote from: amba on 02 September 2020, 10:03:51
I'd forgotten about that.
I'll be in touch
amba
 :y.Did drop you a PM a while back
