Author Topic: Makes a change from "broken coil spring"  (Read 3005 times)
annihilator
  • Wirral
    • Omega Tourer V6
« on: 15 September 2020, 09:09:01 »
Saw this whilst browsing the bay of e 58 plate Ka spares or repair.Quite shocking for a 12yr old car even if it's a Ford
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Makes a change from "broken coil spring"
« Reply #1 on: 15 September 2020, 09:52:42 »
On a 12 year old Ka, it's a surprise those bits still have something to attach to. Unless they're like a lot of old XJs where the IRS was held in by gravity acting on the body above it.....
Try looking under a grey import from Japan sometime, the narrower Previas often have rotted through semi-trailing arms
« Reply #2 on: 15 September 2020, 10:01:27 »
The leaking shock clearly didn't help stem the rust ;D
  • Chatham, Kent
« Reply #3 on: 15 September 2020, 10:26:19 »
Rust flakes destroyed the oil seals?
« Reply #4 on: 15 September 2020, 10:50:01 »
Rusted through from outside by the look of it :D
Although I would wager that the shock bolt is rusted solid ;D
« Reply #5 on: 15 September 2020, 14:15:34 »
Those hateful KAs have loads of rust issues, where else have you seen a commonly used repair panel for the fuel filler......just one of the many tin worm spots on them.
annihilator
  • Wirral
    • Omega Tourer V6
« Reply #6 on: 15 September 2020, 18:01:57 »
It's the MK2 shape 09 onwards which is what surprised me.
  • Chatham, Kent
« Reply #7 on: 15 September 2020, 18:12:31 »
but that's really a Fiat. Which still haven't shaken off the rusty reputation they used to deserve
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #8 on: 15 September 2020, 18:39:05 »
 :-X ,not come across a rotten new shape Ka yet, well until now ;D
other rides
