F/L front O/S Door latch required
Started by fudgee, 11 October 2020, 10:11:24
fudgee
Hello guys  :)
I need a replacement front drivers side door latch for my 2.2 C.D Auto
Part number is 605328
Many thanks
biggriffin
Hoof'land storeman.
fudgee
Sorry guys I completely ballsed that up.
I need the entire lock mechanism and also the solenoid that sits at the bottom of it.
Both are buggered
fudgee
biggriffin
Quote from: fudgee on 18 October 2020, 15:18:05
Both are buggered
Probably find it's the solonoid, you need to find the problem,  is it when remote is pressed door doesn't lock, or can't be opened by using the handle
Hoof'land storeman.
fudgee
At first when you locked the car via the fob all 4 doors would lock and the drivers door would unlock again immediately.
This continued for about 6 weeks and then the drivers door would not close flush.
When you physically pushed it closed it just wasnt catching and securing on the latch.
I literally cannot drive it at the moment as the door swings open at any given moment so Im off the road because of this  :-\
biggriffin
Sounds like you need the locking mechanism, not the solonoid.
Hoof'land storeman.
biggriffin
I've got 09174595. Think it's a rear.
Solonoid 90493703
Hoof'land storeman.
fudgee
Many thanks mate but I need a drivers side front unfortunately
johnnydog
I may have a complete facelift front right hand latch mechanism, but no solenoid (motor). I will check today if that is any use to you.
fudgee
That would be an absolute lifesaver if you have mate.
I can source a solenoid separately.
The main thing is being able to close the door properly because I literally cant drive it until I can do that
Quote from: fudgee on 19 October 2020, 11:59:53
Have you tried moving the 'bear claw' part of the latch that actually engages on the staple on the bodywork? It's not unusual to find that they can get stuck in the closed position, and some manipulating can get them to work again. Copious amounts of solvent cleaner, then lubricant would be a good idea to reduce it reoccurring.
If the latch is loose and not locking into place, then you will need to replace the whole mechanism.
The solenoid continually operating could be the internal microswitch at fault - the forum favourite - or a short in the door wiring loom which was what was actually wrong with mine.
omegod
