Author Topic: Buying a torque Wrench  what type?  (Read 1868 times)
willyboy
  • Leeds. West Yorks
  • Can Do !!
« on: 02 September 2008, 12:39:23 »
Has i do not have a Torque Wrench apart from the older long type with a tension plate & pointer on the handle, which is not much good!
Dont want to spend a fortune on one say £25 max here's link to gaybay for some & also link to one that seems to be ok as I hope to be doing some work on my miggy asap. I have a mixed socket set 3/8 & 1/2 inch so will probably go with 1/2" drive
What you think guys, or any recommendations as to where to buy !
http://shop.ebay.co.uk/?_from=R40&_trksid=m38.l1313&_nkw=Torque+wrenches
http://cgi.ebay.co.uk/1-2-DRIVE-TORQUE-WRENCH-In-Hard-Case-BRAND-NEW_W0QQitemZ150289098959QQcmdZViewItem?hash=item150289098959&_trkparms=72%3A12%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Ian_D
  • York
Re: Buying a torque Wrench  what type?
« Reply #1 on: 02 September 2008, 12:45:46 »
I got one from argos maybe? cant remember now!
But its ok for most stuff, maybe wouldn't trust an engine rebuild with it though! ;D
Think it was £15
Hardly ever use it, just feel for tightness etc :)
« Last Edit: 02 September 2008, 12:47:12 by Ian_D »
[size=12]
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #2 on: 02 September 2008, 13:07:36 »
Well after watching the "How to Cambelt /waterpump change DVD" feel like one would be advisable, actually just found one locally at Machine Mart looks ok !
http://www.machinemart.co.uk/shop/product/details/cht141-1-2in-drive-torque-wrench/path/ratchets-torque-wrenches-2
« Reply #3 on: 02 September 2008, 13:10:26 »
Think a fair few of us have that one ;)
eddys
« Reply #4 on: 02 September 2008, 13:38:11 »
Halfords do a few with diffrent ranges of torque.
There extremely accurate and come with a lifetime garentee and calibration certificate.
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #5 on: 02 September 2008, 13:41:22 »
What about a low values torque wrench for the more delicate jobs?
e.g. Gearbox Sump bolts (9 ft lbs from memory), cam cover bolts.
varche
« Reply #6 on: 02 September 2008, 13:41:54 »
check that certificate ;)
Not very accuarte, but much easier to set than a traditional micrometer.
« Reply #7 on: 02 September 2008, 13:44:05 »
varche
I was nosing through a catalogue in a motor factors the other day and they were selling 1/4 drive torque wrenches which went as low as around 4 ft lbs IIRCC... Unfortunately it's 270 miles away so I can't go and check!! But they were a good price :y :y
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #8 on: 02 September 2008, 16:45:31 »
varche
Meant mainly for bikers ! i believe
ians
  • Reading
« Reply #9 on: 02 September 2008, 17:59:02 »
Sealey do one which has a wide range - you need to go done to 8Nm for some common jobs on the Omega.
Ian_D
  • York
« Reply #10 on: 02 September 2008, 21:36:09 »
Think lowest mine does is about 28nm - hence why I dont often use it!
[size=12]
Ian_D
  • York
« Reply #11 on: 02 September 2008, 21:37:09 »
Snap, thats the one I have! Im sure I got it else where though...
[size=12]
