Facelift F/O/S Door card
Started by fudgee, 24 October 2020, 16:34:15
fudgee
Replacement drivers side front door card required for 2003 2.2 cd auto.
Standard dark grey with mahogany strip.
Damaged mine removing it in order to replace lock mechanism  :-\
New POD
i have a rear one for an mv6 in grey and grey.  free  :y
but not a front one.
fudgee
Thanks for that kind offer pal but its just the drivers front I need unfortunately  :y
johnnydog
I have a drivers door card off a 2002 CDX, not a CD. Never having had a CD, I'm not sure whether there is any difference - the most likely being the pattern of the material under the 'wood' strip.
Are you able to post any trim codes or a part no. embossed in the hard board that may be on the reverse of your old one, or a photo of the trim of yours to compare?
There may also be a CD in a local breakers to me if CDX versions are different - there was a couple in last time I went. I never refuse the opportunity to visit a breakers..... :y (as long as it's fine...;D)
They're the same. Only significant difference is whether the car has leather or not.
Early facelift has matt trim instead of gloss and slightly different lock pins...
Having seen the car, a 2002 Cdx cloth panel in Charcoal will be an exact match.  :y
johnnydog
The CDX it came didn't have leather and it was the charcoal trim. I will physically check it is ok and has no blemishes in the morning.
GastronomicKleptomaniac
If the original rich mahogany trim strip is still intact; and if the replacement card has a different effect trim strip; then its only a matter of drilling the heads off 7 or so plastic rivets to swap the wooden trim :y
fudgee
Wow thanks lads  :y
Some great knowledge and advice right there
johnnydog
A replacement drivers door card will be on its way to you tomorrow with delivery hopefully on Thursday... :y
fudgee
All received safe and sound. Thanks Johnny and everyone else :y
